MK2 Cable Window Regulator
Postby PatoDeServico » Sun Aug 18, 2024 9:56 pm
Greetings!
I recently acquired a 1981 2.4D Mk2 Transit in need of a Window Regulator on the Right Hand side, I've already found loads of the arm type, but mine is a cable operated one.
Does anyone have an extra laying around? Would need to be shipped to Portugal.
Cheers
PatoDeServico
Re: MK2 Cable Window Regulator
Postby Mr twin choke » Tue Aug 20, 2024 8:01 pm
There's a seller on eBay who currently has both sides available.
Is your current one seized? I know from the ones on my MK1 that the grease used to lubricate them resembles something more like glue after 40 + years and dirt ingress. I degreased and pressure washed mine then lubricated them lightly with fresh grease. They now work perfectly with minimal effort required to operate. The window winder handle being broken is usually a tell tale that they need a good cleaning as people try to force them open. When I bought my MK1 it had 2 broken window winder handles in the glovebox as well as 1 broken one fitted to the van. All it needed was maintenance to prevent this.
Mr twin choke
Return to Mk 1 & 2
