Mk1 front disc brakes which rear brake cylinders
Postby Rockinronnie66 » Fri Sep 13, 2024 4:36 pm
Hi recently purchased a mk1 with front discs fitted but needs rear wheel cylinders replaced.
My question is what rear cylinders to fit ? They are 19mm standard bore I could fit 20.30mm bore or would it be better to fit mk2 23.8mm bore?
Thanks Ronnie
Rock”n”Roll Baby!
Rockinronnie66
Re: Mk1 front disc brakes which rear brake cylinders
Postby Ollie » Thu Sep 19, 2024 9:20 am
Hi, I'm doing the same thing on my mk1, but in my case I expect to use absolutely everything from one van. in my case I'm fitting complete mk2 vented discs to a mk1 lwb
which van do you start with, short or long age etc, and which front brakes, bolted on single piston calipers or twin pots? and again from what model van? and finally which master cylinder do you have, or plan to have!
Ideally you want the rear cylinders to match whatever equivilent van your front brakes where fitted too, but if in doubt I'd allways go on the more conservative side to prevent locking up when empty.
Ollie
Postby dumper » Thu Sep 19, 2024 4:59 pm
Back in the day transits were a nightmare to get the correct cylinder sometimes we would fit what ever was available and if necessary we would adjust the L A V valve to suit if the efficiency was down or locking the rear brakes.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Return to Mk 1 & 2
