mk1 steering box adjustment
Postby baconsdozen » Fri Nov 29, 2024 12:03 pm
Has anyone got a better method of adjusting a MK1 box? Mine has play when the wheel is turned over but very littkle in the straight ahead position. The annoying thing is it doesnt stay in adjustment but alters after any turning of the wheel hard (parking etc).
baconsdozen
Re: mk1 steering box adjustment
Postby dumper » Fri Nov 29, 2024 12:32 pm
Have you tightened the ajuster on the side of the box the one with a 17 or 19 mil nut and a screwdriver slot in it if you have and it hasn’t helped the n your box is too badly worn also if you over tighten it you will get a stiff spot in the steering
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby baconsdozen » Fri Nov 29, 2024 4:14 pm
Yes tried the conventional setting procredure but it doesnt stsy adjusted for long. i guess the box has pretty much had it and presumably parts for them are about as rare as an honest politician.
baconsdozen
Postby dumper » Fri Nov 29, 2024 4:43 pm
Don’t now were were you can find the parts but you have no chance then finding a honest politician someone on here running a mk one will turn and be able to help
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Return to Mk 1 & 2
