what dot brake fluid should i be using
Postby shepped0 » Sun Dec 22, 2024 3:22 pm
Hi All
Looking to change my brake fluid on my mk1 and ashamed to say i have never done it in all the years i have owned it. Question is what grade type of fluid should i be using ie Dot 3 or 4 or something else. Believe also i may have a fluid leak near the master cylinder so plan to check them all in the new year and start by getting the correct fluid
thank you
shepped0
Re: what dot brake fluid should i be using
Postby shepped0 » Tue Dec 24, 2024 12:23 am
Anyone ?
shepped0
Postby Soren » Tue Dec 24, 2024 7:44 am
Hi
I youse Dot 5,1 in min,
Søren
Transit MK 1 1977 Essex V4 2,0 Autocamper
Volvo V60 D2/D3 2013
Harris Magnum 2 GPZ 1100 1984
Kawasaki GPZ 1000RX 1988
Aberdeen Angus cattle approx 35
MF 135 1973
David Brown / Case 1390 1982
Soren
Postby Altransit » Tue Dec 24, 2024 2:20 pm
Dot 4 should be fine in an older braking system.
Postby shepped0 » Fri Dec 27, 2024 12:14 am
Thanks Guys for your replies DOT 4 it is then i have a horrible feeling i have fluid coming from my master cylinder....I know i can get a refurb kit for it but what are the chances of getting a replacement part i am guessing zero?
shepped0
Postby Altransit » Fri Dec 27, 2024 11:38 am
If you can find any numbers stamped on the unit, it's worth a try googling that number.
Postby shepped0 » Fri Dec 27, 2024 12:16 pm
Thanks again going the attempt in the new year
shepped0
Postby Ollie » Sun Dec 29, 2024 1:13 pm
if you need a master cyl I find Autodoc have all sorts of random stuff, and motomobil will prob have something at a price. in Uk contract auto engineering in stourport have just refurbed my mk2 cyl with a stainless sleeve.
Ollie
Ollie
Postby shepped0 » Sun Dec 29, 2024 1:22 pm
Ollie wrote:if you need a master cyl I find Autodoc have all sorts of random stuff, and motomobil will prob have something at a price. in Uk contract auto engineering in stourport have just refurbed my mk2 cyl with a stainless sleeve.
Ollie
Thanks Ollie used motomobil in the past for brake stuff
shepped0
Return to Mk 1 & 2
