Late mk1 Transit Kingpin reamer size. straight pins and disk
Postby Viva_65 » Wed May 07, 2025 7:04 am
Hello, Im about change both kingpins in my mk1 camper, i have allot of up and down movement.
I would like to get all the tools ready before i start, ive read i need a adjustable reamer for the bushing. Does anyone know what size range that reamer needs to be?
Also if my bushes are okay will i get away with just replacing bearing? or am i most like to damage the pins on removal. Thanks in advance
Viva_65
Re: Late mk1 Transit Kingpin reamer size. straight pins and
Postby Ralph.9 » Wed May 07, 2025 8:22 am
I just changed the bearings on my MK1 to remove the lift so yes its ok to just change them.
Ralph.9
Postby Mikexx » Wed May 07, 2025 11:50 am
Viva_65 wrote:Hello, Im about change both kingpins in my mk1 camper, i have allot of up and down movement.
The manual says that split bushes are used and to use a broach rather than a reamer. Sounds a faff.
If you have minimal lateral clearance then just change the bearings. I would recommend getting the beam off and using a press. Pins on some vehicles (not sure about the Mk1) are soft and hammering is not a good option.
Mikexx
Postby Viva_65 » Thu May 08, 2025 4:33 pm
Okay so the reamer is for the kingpin sliding into the beam. And if all goes well removing them i should not need to ream anything,
I will do both sides at once so i was going to take the beam off and do it all inside the workshop.
Super i have everything i need then thanks guys
Viva_65
Return to Mk 1 & 2
