Starter smoking
Starter smoking
Postby dredds » Thu Jan 10, 2008 10:07 am
Morning all...
I am having trouble starting the old bus. I have burnt out one starter. Isn't the bit the +ve supply goes into called the ballast resistor? This smoked whilst winding and then it packed up.
I have fitted a replacement from a breakers yard and whilst it started OK the first time whilst being jumped from another vehicle, when being started on its own, the engine winds and the ballast resistor gets hot and starts smoking. I have stopped trying in case I burn this one out completely as well.
The fact that it winds for so long could be due to perishing fuel pipes and I plane to sort those out soon, but it has always started eventually in the past, now it wo't.
Any ideas??
Kevin.
1985 Mk2 with early 2.5DI...
PS jave just put a deposit down on a 54 plate 260 SWB Medium Roof Van TDi, so HOPEFULLY the bus can be retird into social uise only!
dredds
Re: Starter smoking
Postby MrMPuk » Thu Jan 10, 2008 10:26 am
By ballast resistor do you mean starter solenoid? My guess is your battery is goosed which is why it started fine when being jumped but now that you are starting it on it's own the increased current due to lower voltage and prolonged cranking is burning out the solenoid and starter.
Re: Starter smoking
Postby dredds » Thu Jan 10, 2008 10:55 am
Yes, I guess it is the solenoid...
I'll run a meter across the battery and see what its showing. Seems to hold a charge tho...
Kevin.
dredds
Re: Starter smoking
Postby MrMPuk » Thu Jan 10, 2008 10:57 am
Could even be a bad connection or earth which will also increase current.
Re: Starter smoking
Postby dredds » Thu Jan 10, 2008 11:02 am
Its showing 13v. Earth should be OK - its running straight to the starter motor housing, +ve is good also. I have a spare battery - I'll try that later on.
dredds
Re: Starter smoking
Postby MrMPuk » Thu Jan 10, 2008 11:03 am
How long is it cranking before it starts?
Re: Starter smoking
Postby dredds » Thu Jan 10, 2008 11:17 am
Tuesday it cranked for probably 20-30 turns, and started, yesterday cranked on and off for 60+ I would guess and didn't start at all.
dredds
Re: Starter smoking
Postby MrMPuk » Thu Jan 10, 2008 11:19 am
Well that's your problem then! It's getting hot because you are cranking it for far to long!
Re: Starter smoking
Postby dredds » Thu Jan 10, 2008 11:24 am
Whats the option if she don't start????
dredds
Re: Starter smoking
Postby MrMPuk » Thu Jan 10, 2008 11:28 am
dredds wrote:Whats the option if she don't start????
Find and fix the problem that is stopping it from starting before you kill another starter motor!
Re: Starter smoking
Postby FredTransit » Tue Jan 15, 2008 3:03 pm
This is a DI right? When did you last change the oil? Cold, thick oil gives the engine more resistance, making it slower to crank.
FredTransit
Mk2 Trannyist
Re: Starter smoking
Postby dredds » Tue Jan 15, 2008 6:20 pm
Hi Fred...
Now that's point - I've recently changed the oil - I bet I've used the wrong grade - can't remember what I put in, I'll have to check the empty cans. What grade should I use?
It is (I believe) the early DI - I've been told that the 1985 model used an odd engine between old and DI...
Many thanks...
dredds
Re: Starter smoking
Postby FredTransit » Tue Jan 15, 2008 7:45 pm
Do you mean the York? Can't remember what grade of oil without going down to the van! Your van should have a proper DI, all be it an early one.
FredTransit
Mk2 Trannyist
Re: Starter smoking
Postby dredds » Fri Jan 25, 2008 11:10 am
Hi Fred - delay in replying due to lurgy...
I used 20w50 - should have used 15w40 I guess...
dredds
Re: Starter smoking
Postby MrMPuk » Fri Jan 25, 2008 7:33 pm
dredds wrote:Hi Fred - delay in replying due to lurgy...
Or even 10w40
Return to Mk 1 & 2
