Looking for 2 rear hub seals / bearing kits for 1968 Transit
Postby Wilack » Thu Nov 27, 2025 6:01 am
Anyone know where i might source 2 rear hub seals or wheel bearing kits if they come with seals for:
1968 Transit 2,0 v4 with the square axle...can get more info if required.
Wilack
Re: Looking for 2 rear hub seals / bearing kits for 1968 Tra
Postby metalworker0 » Fri Nov 28, 2025 10:09 pm
i dont know, as i don't know the model designations as im not the owner oof such a transit not my area
is this it .. i suppose in 1968 everything was the same across the whole range .. i could be wrong . this is for transit mini bus .. of the era .. picked out at random
https://www.onlinecarparts.co.uk/mapco-2033962.html
or one page back you have choice
https://www.onlinecarparts.co.uk/car-br ... html#10785
what you need to find is a car parts numbers catalogue site like catcar.info .. but goes back further like example above or even that site .. sorry don't know if that actual site are good company or not
picture screen shot of menu on site /..,... pick your van out of that lot and you may get somewhere.
so that's really how we do it .. how we find parts
once you have the ford part number .. you can put into ebay and it will find it ... may be the same and fit other cars of era like cortinas , escorts, anglias etc
main menu ... this is not a recommendation ..
https://www.onlinecarparts.co.uk/car-br ... ansit.html
Return to Mk 1 & 2
