Looking for the speedometer driving gear for my MK2 transit
Postby hab » Thu Nov 27, 2025 11:14 am
Hello everyone,
Very recently the speedometer driving gear of my MK2 petrol Transit worn out, and now the speedometer is not working. Unfortunately I cannot find this part anywhere.
There where different such driving gears for the MK2 Transit, but the one I need is for the F type geabox with 22 teeth. Please see below:
https://www.motomobil.com/en/products/g ... -4496710-2
I know in the past this part was constructed by some specific machine shops, but unfortunately in Greece I cannot find anyone who does this anymore.
Some people proposed 3D printing it (the worn part is plastic), but I am not sure if this is even possible.
Does anyone have any such experience, or does anyone know any machine shop which can still make such gears?
hab
Re: Looking for the speedometer driving gear for my MK2 tran
Postby Chug » Fri Nov 28, 2025 12:46 am
Part number 4496710 comes up with this
https://www.bearingkits.co.uk/TYPE-9-GE ... #gsc.tab=0
Chug
Postby bortaf » Fri Nov 28, 2025 8:43 am
are you sure it's a type F gearbox? with external gear linkages ?
try burton power they list 22 teeth drives but for the type E and type 9
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby hab » Wed Jan 07, 2026 8:51 pm
Thank you for your replies Chug and bortaf!
The part which I removed from my Transit had the number 11 449 671 (see below) and from the Motormobil website I came to the conclusion that my gearbox type is F. Unfortunately I do not know how to determine the gearbox in any other way.
I will try to buy this part from bearingkits when it comes available again, but I also found a machine shop which manufactured the gear using brass. The only problem is that we did not know the initial width of the gear (mine was pretty worn), so I am not sure if it will work. In any case I will keep you updated.
hab
Return to Mk 1 & 2
