Clutch cable
Clutch cable
Postby 32evo » Sun Feb 10, 2008 4:53 pm
The clutch cable on my 2.0 petrol swb is broken, can anyone tell me how to get the cable off the top of the pedal?
32evo
Re: Clutch cable
Postby Neil » Sun Feb 10, 2008 5:08 pm
is it not threaded :?:
Neil v6
Neil
Re: Clutch cable
Postby 32evo » Sun Feb 10, 2008 5:22 pm
Neil wrote:is it not threaded :?:
I dont think so, it looks as though its attached to a small red clip type thing on the pedal. I may have to take the pedal off, is this easy enough to do?
32evo
Re: Clutch cable
Postby Luke » Sun Feb 10, 2008 5:29 pm
if its the arched shaped plastic piece type then the bit needs priseing out then you can spin it round and there is a metal pin about ½" long this will come out of the eye on the cable then its fairly obvious what to do :D
hope that helps - its easier to do than it is to describe :lol:
Re: Clutch cable
Postby 32evo » Sun Feb 10, 2008 7:43 pm
Luke wrote:if its the arched shaped plastic piece type then the bit needs priseing out then you can spin it round and there is a metal pin about ½" long this will come out of the eye on the cable then its fairly obvious what to do :D
Would it be easier to take the pedal off as it looks a bit fiddly to take the cable off in situ?
32evo
Re: Clutch cable
Postby Luke » Sun Feb 10, 2008 7:47 pm
no its a dead easy job - once you realise how its done :D
if you slide a screwdriver between the plastic bit and the pedal and twist it the plastic bit should come uncliped :D
then you spin it round and pull it away from the pedal and it unclips from the cable - but there is a pin left in the cable - make sure it doesnt fall out and get lost :lol:
Re: Clutch cable
Postby 32evo » Sun Feb 10, 2008 8:14 pm
Luke wrote:no its a dead easy job - once you realise how its done :D
Thanks for your help, i will try tomorrow.
32evo
Re: Clutch cable
Postby FredTransit » Fri Feb 15, 2008 9:08 pm
Once it's off the gearbox end (they are usually snapped off at one end) it will easily come off the other end.
FredTransit
Mk2 Trannyist
Return to Mk 1 & 2
