Replacement engine for Mark 1
Postby brichart » Tue Feb 19, 2008 7:56 pm
Hi All,
After all sorts of diagnosisis, it appears our engine may have seized. It is currently a V4 2000E and we are wondering what is the easiest and cheapest replacement? Are there any modern equilevents we could use and can we have a diesel engine if it is currently petrol?
Would be most grateful for any advice or tips, :D
Cheers
Beth
brichart
Re: Replacement engine for Mark 1
Postby Luke » Tue Feb 19, 2008 9:51 pm
your biggest problem is the van is designed round the V4 format - to put a 'normal' engine in will need the bullnose fitting :D
it is possable to fit a pinto in with the flat front but its a squieze and not a job for a novice :|
Postby FredTransit » Thu Feb 21, 2008 11:45 pm
Again your diesel option would include the bull nose and the best bet would be a DI.
FredTransit
Mk2 Trannyist
Postby comet » Fri Feb 22, 2008 12:15 am
friend of mine got a 1800 turbo out of seria, still flat front, pulls ok in little pop top
1971 LANDLINER - 2.5DI FITTED NEW BY FORDS IN 2000 - IF YOU WANT A COVER UP ASK THE POLICE THEY ARE THE BEST
comet
Postby FredTransit » Fri Feb 22, 2008 12:48 am
Interesting, where did he put the rad, and did he have to do any firewall mods?
FredTransit
Mk2 Trannyist
Postby MrMPuk » Fri Feb 22, 2008 12:51 am
FredTransit wrote:Interesting, where did he put the rad, and did he have to do any firewall mods?
Probably the same way Mark fitted the pinto with the flat front.
Postby FredTransit » Fri Feb 22, 2008 12:53 am
I thought Mark kept the bullnose.
FredTransit
Mk2 Trannyist
Postby MrMPuk » Fri Feb 22, 2008 12:58 am
FredTransit wrote:I thought Mark kept the bullnose.
Nope.
Postby baconsdozen » Fri Feb 22, 2008 8:56 am
Surely the logical thing would be to work out if the engine has seized,if so why and can it be repaired.Try putting a 5/8 socket on the crank pulley and seeing if it will turn,if not drop the sump and have a look.
baconsdozen
Postby MRspivvy » Wed Mar 05, 2008 11:11 am
If it was mine I think I'd change the engine anyway, v4s are getting a little thin on the ground now and it has to said not the best engine. would it be worth fitting a 1.6 kent crossflow, should be able to keep the flatfront then, and plenty of uprading bits are available for it
MRspivvy
Return to Mk 1 & 2
