MK1 brake shoes+wheel cylinders in AUSTRALIA - urgent
Postby browneye » Fri Nov 18, 2005 2:31 am
Hey all, im in australia and am having a massive ammount of trouble trying to find brake shoes and wheel cylinders (more importantly brake shoes) for the front and rear of my mk1 transit (1972)
can anyone help me out? anyone in australia with a MK1 that has gotten ahold of these before?
also im interested in getting some parts sent over from the uk, where it seams parts like this are very very easy to find... id be interested in getting all 4 wheel cylinders and all the shoes sent over. anyone want to help me out?
cheers
Matt.
browneye
Postby MrMPuk » Fri Nov 18, 2005 2:50 am
Your brakes will be different to ours over in the UK mate as you run different axles!
Postby browneye » Fri Nov 18, 2005 3:51 am
yes good point, for got about that. any fellow aussie tranny owners have any luck?
browneye
Postby Sundowner » Fri Nov 18, 2005 7:05 am
Time to fit falcon discs and HX callipers
Castlemain Rod Shop do a conversion kit for drum transits
If your freaking about the price of lenses you dont want to ask about brake parts
To rebuild a transit 2 piston calliper it will cost $200 for pistons and $90 for a seal kit compared to $40 odd to do the HX unit
A new non vented 270mm disc will cost $210 and a 285mm vented and slotted falcon disc will cost $140
It would be a good move as you get a 285mm vented discs and a very strong and cheap calliper
You also end up with a good stud pattern and have a big choice of wheels
I was lucky with my van, my 2 piston callipers and solid discs were stuffed
But i managed to get my hands on some rebuilt 4 piston callipers and near new 270mm vented transit truck discs for nothing, But you need to modify your hubs so the calliper clears them
Sundowner
Postby cad69 » Fri Nov 18, 2005 7:08 am
[quote="browneye"]yes good point, for got about that. any fellow aussie tranny owners have any luck?[/quote]
Going way back in my memory I used to exchange old shoes with new ones where they used the old ones to bond new material to resell which means you should be able to get your old ones done up. Grab an old pair at a wreckers to save being off the road too long. I'm sure a generic ford cylinder kit will fit the cylinders. It was pretty standard in the old days for cylinders to be rehoned and new seals.
Cad
cad69
Postby Sundowner » Fri Nov 18, 2005 9:58 am
Or you could just get the drum parts of Brake Parts Australia
http://www.bpa.com.au/home.html
Sundowner
Postby cad69 » Fri Nov 18, 2005 12:51 pm
[quote="Sundowner"]Time to fit falcon discs and HX callipers
[/quote]
Yo Sundowner
What's involved in the conversion? Sounds like the way to go.
Cheers cad
cad69
Postby Sundowner » Sat Nov 19, 2005 3:12 am
Dont know whats involved exactly but im guessing its the same as the swap i did to my cortina as transit and TE cortina have the same stub size
What i had to do to the cortina was use XA 2 peice hub/discs discard the original discs and have the face of the hub turned down 9mm to get the correct offset for the calliper
Got a new pair of slotted discs from RDA and pressed in the new studs supplied in the CRS kit
Fit a new set of HQ wheel bearings
sourced and rebuilt a pair of HX callipers and fit them to the stubs using the adaptors in the kit
had a pair of stainless lines made
Prices
CRS Conversion kit $210
RDA Slotted discs $280 pair
XA hubs $50
Machine hubs $50
HX callipers $90 pair
Rebuild callipers $80 pair
HQ bearings $50 pair
Stainless lines $180 pair
TOTAL $990
Still not cheap to do but it will be cheaper next time you need to do the brakes
Sundowner
Postby cad69 » Sat Nov 19, 2005 3:42 am
Mmmmm.......
I think I'll just buy an old Mk2 and swap parts but thanks for the info.
Cad
cad69
Postby Sundowner » Sat Nov 19, 2005 7:51 am
You can go that way too
so say you get a mk2 that has'nt been driven for a while for $500
You pull the brakes and find the pistons are rusted and you need new pads
what are you going to do? you cant just push the pistons back and fit new pads as the rust will damage the seals and they will leak
Pistons for these are between $90 and $117 and theres 2 in each calliper
seal kits are $90 each and the pads are around $70
Thats nearly $720 just to rebuild the callipers :shock:
And your still stuck with tiny pads
What if the discs are rusted? yeah you could go and get them surfaced but what if their already at their minimum?
Discs are around $210 for a non vented 14.3mm thick discs
You could be up for nearly $1700
You may be lucky and get a van that has really good brakes then you may not, I dont like to see people get ripped or do them selfs out of cash
If i didnt get my hands on the other brakes i would have gone with the falc discs
You can do the conversion a little cheaper by not using the braided lines and slotted discs this would save you nearly $300
Sundowner
Postby cad69 » Sat Nov 19, 2005 9:34 am
[quote="Sundowner"]You can go that way too
Ok you've talked me into.... I'll do nothing!! <grin> When the drum brake cylinders die (probably in dingo territory) I'll see if I can adapt some other Ford cylinders. Shouldn't be too hard.
Still not convinced UK parts arn't interchangable, rear axles might be different but drums etc are probably same, no reason for them to change them unless they were using parts from Falcon which means I should find them elsewhere.
Cheers
Cad
cad69
Postby Sundowner » Sat Nov 19, 2005 10:22 am
Sorry man didnt mean to put you off
BPA will have the parts you need
Supercheap can get shoes I checked their brake book while i was there and it a listing for transit
If you cant find new cylinders you can always get you old ones resleeved
Oh and front brakes are the same as UK
Sundowner
Postby stooy » Sat Nov 19, 2005 1:03 pm
Hey browneye, Bernies Brakes in Dandenong can reline your old mark 1 shoes and repiar wheel cylinders, they also can source flexy hoses. 3
They did my whole brake setup, it cost alot but its been perfict since then.
BERNIES BRAKE SERVICE SPARE PARTS PTY LTD
16 Plunkett Rd Dandenong 3175 (03) 9792 0418
stooy
Re: MK1 brake shoes+wheel cylinders in AUSTRALIA - urgent
Postby cad69 » Sun Nov 20, 2005 12:22 am
[quote="browneye"]
also im interested in getting some parts sent over from the uk, where it seams parts like this are very very easy to find... id be interested in getting all 4 wheel cylinders and all the shoes sent over. anyone want to help me out?quote]
Hey Matt:
http://cgi.ebay.co.uk/FORD-TRANSIT-Mk-1 ... dZViewItem
cad69
Postby MrMPuk » Sun Nov 20, 2005 3:15 am
You haven't quite got the quote thing down have you cad, try prieviewing your posts to see if it has worked
Return to Mk 1 & 2
