Retrohowla wrote:thanks for the link, its pretty indepth mind
i will be trolling through that to pick up some pointers but so far i can see the benefits i could gain just by taking the air from a high pressure zone so thanks!
You never know, it might be worth a try
it mostly boils down to making the flow smooth
things like the ribbed flexie hoses being changed to smooth pipes and just a small flexie joint ,or the way air boxes are baffled and where you take your air inlet from
things like on my old sierra 2L injection the air inlet came from a flexie feed from the side of the inner wing so it had dusty or damp air depending on the weather so i made a duct from a square to round drain adapter and fed the air filter from a spot light blank in the front bumper ( ford later changed to a plastic duct feeding from behind the bumper ) this was worth 2 whole bhp on a rolling road
( checked when i had an emerald injection system fitted )
i would agree about the drag from a scoop (+ most home made and some pro made are hideous
) but air taken from a grill or in / under the bumper and with provision for draining as it goes can be good
i think jags used to take air from a grill above the head lights to feed the vent system in some of the saloons
