Hand brake possy.
Hand brake possy.
Postby cad69 » Sun Nov 20, 2005 6:34 am
Hi Guys
Anyone found that the handbrake lever is too low? Mind you I have well padded high back seats which may well be causing the problem. Anyone know of a simple conversion to a higher lever? Problably doesn't help that you have to reef on the thing so hard.
What happens if you do a handbrake turn in a tranny..... probably fall over :shock:. I'm not game to try, must be getting old.
Cad
cad69
Postby MrMPuk » Sun Nov 20, 2005 1:51 pm
I don't bother using the handbrake! It's to far away!
Postby Luke » Sun Nov 20, 2005 1:54 pm
MrMPuk wrote:I don't bother using the handbrake! It's to far away!
how do you get round those tight corners? :?
how about fitting a mk3 handbrake? is that higher up? also it might fit the same mountings!
certanly the mk6 handbrake is higher up!!
just a thought :idea:
Postby cad69 » Sun Nov 20, 2005 11:34 pm
Luke wrote:how about fitting a mk3 handbrake? is that higher up? also it might fit the same mountings!
Good thoughts, will check.
Cad
cad69
Postby Luke » Sun Nov 20, 2005 11:49 pm
i will check aswell, if it is i will be swapping mine too!!! :D
Postby Sundowner » Mon Nov 21, 2005 6:20 am
If its anything like the MK2 unit im sure you could make a steel extension for it to sit on and just extend the rod that goes from the lever to the pivot under the floor :?:
Sundowner
Postby cad69 » Mon Nov 21, 2005 6:56 am
Sundowner wrote:If its anything like the MK2 unit im sure you could make a steel extension for it to sit on and just extend the rod that goes from the lever to the pivot under the floor :?:
Yep, just had a crawl under the beast and came to the same conclusion.
Cad
ps Could probably make it into a kit form and sell on ebay! :twisted:
cad69
Return to Mk 1 & 2
