mk2 leaf springs and bushers
Postby JIM T » Sat Jun 21, 2008 12:39 pm
Hi there everyone I have a question about leaf springs on my mk 2 Transit ford Hymer ,can someone tell me what mark transit will fit as replacements on the mk2 i.e mk 3 mk 4 mk 5 and so on,and is there any modification to do.The hymer flew through the MOT with the remark from the tester '' I CAR'T FIND A THING WRONG AND I'VE HAD A GOOD LOOK'' ,be before the test I had to trim around a spring bush it was bulging out ,I have look on the net for knew bushers but had no look so is there any one out there that can help cheers from JIM T. :)
Yes it is a Transit MK 2 under there some were.Click here for pic!
[http://s233.photobucket.com/albums/ee82/JIMRT/#!cpZZ7QQtppZZ16]
JIM T
Re: mk2 leaf springs and bushers
Postby transitexpress » Sun Jun 22, 2008 2:13 am
Try a local Spring Manufacturer / Repairer. :)
Old transits need never die just keep mending em!
transitexpress
Postby JIM T » Sun Jun 22, 2008 8:06 am
Hi there ,I emailed a spring maker and the replie was to send him some mesurment and he would have a look, but the problem is when I take the spring off to mesure it I would like to have one their and then to fit back on .Last night I found one on EBAY I bought it there and then I JUST HOPE IT FITS ,the seller sold it has mk1 -mk3 but I have been told that a mk 3 bush will not fit, so its all up in the air until it comes ,Cheers mate :)
JIM T
Postby Luke » Sun Jun 22, 2008 9:24 am
i fitted mk3 springs on my 67 mk1 - pritty sure they will fit on the mk2 and i think the bushes were the same - if not i must have used the mk3 bolts either way i got them fitted :D
Postby Neil » Sun Jun 22, 2008 11:46 am
should fit,,, however petrol and diesel fronts are tempered differant they look the same but if its an early petrol and you have a di in yours it will give it the dragster look :roll: ebay is a risk with springs :!: try rossendale road springs if he has none he can re con yours
Neil v6
Neil
Postby ray78dtv » Thu Jul 17, 2008 2:14 pm
do you have contact info for rosendale road springs? regards ray78dtv
ray78dtv
Postby FredTransit » Thu Jul 17, 2008 3:33 pm
Don't know about rosendale, but there are 2 spring suppliers in the supplier's listing.
FredTransit
Mk2 Trannyist
Return to Mk 1 & 2
