by baconsdozen » Tue Jul 01, 2008 8:21 am
You'll have to probably start from scratch.
From the ignition a wire goes to the on/off switch on the gear lever.From there another wire goes to the switches on the box itself,The idea is that in any other gear other than 3 or 4 the circuit is broken regardless of the position of the gear lever switch.After the switches on the box it ends up feeding the solenoid on the back of the box,another wire completes the connection to earth.
Make sure there is no way current can be supplied to the solenoid in reverse (because it will instantly wreck the box beyond repair) and not in 1 or 2 (to avoid over revving).There is a third switch on the box which operates the reverse lights,you can work out which is which with a meter or test light bulb.
