I purchased the 2.5 when it was already out of the van, and as it differs from my 2.4 considerably, I'm a bit stick on what goes where! I tried to start it today for the 1st time, and it didn't go as well as planned. I've had petrol motors all my life, so I'm a little bit in the dark with regards diesels & how to trouble shoot . But my 1st question of many is:
Does the 2.5d have 2 fuel inlets? If so (& I think it does), does it make any difference which hose from the tank goes where? I found the fuel pump, and assume I stick my hose on the top section. Is that right? If I disconnect the bottom one, diesel should squirt through?
If there are 2 fuel inputs, is the 2nd one on the connection above the cylinder thing on the far left facing the firewall?
Devs
