bosch diesel pump change over
Postby foggy08 » Tue Jul 15, 2008 6:27 pm
hi i was wondering how easy it is to change from a lucas cav fuel pump to a bosch,from a from a wvo point of view,is there a certain pump you need to get ?,do you need the injectors to match the pump,do they both use the same pulleys,etc .what problems could i encounter,and if it all goes pear shaped,is it just a case of throwing in the lucas cav again ?..........just wondering ,not intending to do this for the time being
ouch ..suarez bit my finger
foggy08
Re: bosch diesel pump change over
Postby FredTransit » Tue Jul 15, 2008 6:30 pm
You will need to match the injectors to the pump, the good news is the block is the same on all DIs so if the worst came to the worst you can go back to the Lucas.
FredTransit
Mk2 Trannyist
Postby foggy08 » Tue Jul 15, 2008 8:05 pm
any idea of pump numbers eg :would this one do,http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... BS:GB:1123 and if so how would you find the injectors to match?..........sorry i never even noticed if it was a bosch or lucas
foggy08
Return to Mk 1 & 2
