85 Mk2 Di Fastener sizes
Postby Pikeydave » Wed Aug 13, 2008 9:16 am
Socket/spanner sizes please for:
Wheel nuts
Sump plug
4speedO/D gearbox refil/drain
Diff
Injector(or any other fav bleed spot)
Brake caliper nipples
Ta.
Dave
Pikeydave
Re: 85 Mk2 Di Fastener sizes
Postby FredTransit » Wed Aug 13, 2008 11:26 am
Wheel nuts - 15/16th not 100% about mm, may be 22mm
Sump plug - special tool though there may be a socket to fit
4speedO/D gearbox refil/drain - sorry no idea
Diff - again no idea, but you shouldn't need to do anything with this
Injector(or any other fav bleed spot) - 13 or 10mm, can't remember!
Brake caliper nipples - I have a special spanner for this, but a regular one may fit
Most things on a Mk2 can be undone with either a 10, 13 or 17mm spanner. A set of torx (star) drivers are a plus too. Are you asking in case anything goes wrong on the road or for when you are in the garage?
FredTransit
Mk2 Trannyist
Postby MrMPuk » Wed Aug 13, 2008 11:43 am
15/16th is exactly the same as 24mm.
Postby FredTransit » Wed Aug 13, 2008 11:58 am
Thanks, I only have the 15/16th not mm one.
FredTransit
Mk2 Trannyist
Postby Pikeydave » Wed Aug 13, 2008 12:06 pm
Before doing 2000Kms in a vehicle that hasn't turned a wheel in years I'm going to change the engine oil and filter and check diff, gearbox levels and make sure the brakes seize in the off position!
I'll take my 11mm brake nipple spanner then.
Pikeydave
Postby FredTransit » Wed Aug 13, 2008 12:19 pm
I would not worry about the diff, unless it's got an outrageous leak and you suspect it's lost a lot. Driving a short distance will tell you what condition it's in, some whine is normal BTW.
FredTransit
Mk2 Trannyist
Postby Pikeydave » Thu Aug 14, 2008 11:09 am
I'm off. Poole Cherbourg ferry. 1245pm. Back by Thursday, one way or another.
Pikeydave
Postby The Docmeister » Thu Aug 14, 2008 4:14 pm
Good luck Dave, hopefully not too long before i try something similar!
The Docmeister
Postby FredTransit » Fri Aug 15, 2008 1:46 pm
Good luck! Can't wait to see how you get on!
FredTransit
Mk2 Trannyist
Postby Pikeydave » Mon Aug 18, 2008 10:12 pm
Update:
I'm down here after a 15hr and 1006.7 mile ride from Paris, which included a puncture and mullering someones mountain bike casually discarded in the fast lane of the autostrada. Luckily the Claude Butler didn't stand a chance against 300kilos of BMW GS doing 90!
Now with the Outlaws and on baby sister's dialup computer and the old man's homemade wine.
The Van.
It's virtually rust free and the chassis is sound and very clean. It's spent its life collecting olives! What a perfect rust preventer. Some F%£ker has nicked the front indicators since the pictures were taken and cut the loom off to get them (anybody got some indicators?)
It needs some exhaust mount rubbers and maybe a couple of front tyres though the spare's good. The twin battery looms gone and it's been wired for a battery behind the seat, so should be easy to power up. Handbrake's not seized and it rolls. Oil level is up and don't look too bad, water is showing in the reservoir with a weeping overflow hose (easy to fix)
Brake fluid need topping up and that's about it.
It,s a Koln built 130 Di chassis noWFOVXXGBVVFK52117.
Didn't think a 3tonner would have twin wheels?
Tomorrow I'm up early to beat the sun to get a battery and some fluids to get it running.
If you want some pics, someone PM me a mob number if you can multimedia and host some. it'll make it more interesting. You up for that Fred?
Pikeydave
Postby FredTransit » Mon Aug 18, 2008 10:20 pm
I have a couple of phase1 indicators that will get you home, and you can fit Mk3 bulb holders. They are more reliable as they don't have any rubber to perish in them. They fit directly into the back of the Mk2 indicators as normal.
FredTransit
Mk2 Trannyist
Postby Pikeydave » Mon Aug 18, 2008 10:31 pm
FredTransit wrote:I have a couple of phase1 indicators that will get you home, and you can fit Mk3 bulb holders. They are more reliable as they don't have any rubber to perish in them. They fit directly into the back of the Mk2 indicators as normal.
Cheers Fred
I'll make a decision tomorrow whether to drive straight back or leave it with relatives. I've still got the side repeaters and could chance it back with those alone!
Another detail question. The drivers mirror is mounted on the wing whilst the pass side is door mounted and of a diff design. Is that standard?
Just PM'd you by the way.
Pikeydave
Postby FredTransit » Mon Aug 18, 2008 11:04 pm
The mirrors are the same in RD and LHD, the driver'#s is mounted on the wing and the passenger on the door. They should be the same design though, just slightly different lengths. I don't know if you would get away with having no indicators in the UK bit of the trip. Watch out for VOSA at Dover if you go that way, they hang around at peak times in the truck section, so follow the cars.
FredTransit
Mk2 Trannyist
Postby Pikeydave » Mon Aug 18, 2008 11:32 pm
FredTransit wrote:The mirrors are the same in RD and LHD, the driver'#s is mounted on the wing and the passenger on the door. They should be the same design though, just slightly different lengths. I don't know if you would get away with having no indicators in the UK bit of the trip. Watch out for VOSA at Dover if you go that way, they hang around at peak times in the truck section, so follow the cars.
The UK bit of the trip is about 6 miles!
I forgot to mention the 3 wasp nests secreted around the van!
Pikeydave
Postby Pikeydave » Mon Aug 18, 2008 11:44 pm
Off to bed now, am knackered. Freds got me number and I'll keep in touch via him but knowing the legendary reliability of transits, all I'll do is put a battery on, fill it with diesel, start it up and drive 2000Kms!
Pikeydave
Return to Mk 1 & 2
