how to paint a camper?
Postby foggy08 » Fri Aug 15, 2008 3:50 pm
hi ive a mk2 ci autohome .the cab is white and bright and fresh,butthe camper is 70s beige in colour and is very tired.and i would like to brighten it up.now ive 3 choices...
1/ dulux and roller or brush
2/ car paint and roller or brush
3/ ive spray painting equipment(compressor and spraygun ) but no knowledge of how much paint to thinners etc or technique..
or should i get tore in with tcut and elbow grease ......... your opinion would be appreciated
ouch ..suarez bit my finger
foggy08
Re: how to paint a camper?
Postby FredTransit » Fri Aug 15, 2008 4:02 pm
I would test a small area with T cut or rubbing compound first, you might be pleasantly surprised by the result. If you are still not happy go with the car paint and roller, it's a flat surface and would polish up well. Prep is everything.
FredTransit
Mk2 Trannyist
Postby chipv8 » Fri Aug 15, 2008 5:09 pm
Ask your local car paint store and make sure you know what its made of (Ally/steel/fiber glass) because it all makes a difference if cost is the limiting factor go with hamerite and a roller, its self leveling, hard as nails and should polish up nice :)
Back In the Black Country!!
chipv8
Postby FredTransit » Fri Aug 15, 2008 5:12 pm
It shouldn't matter what the camper is made of as it already has a finish on it. As long as that paint is sound, clean and keyed up it should take new paint.
FredTransit
Mk2 Trannyist
Postby Watto » Fri Aug 15, 2008 10:14 pm
I have a MK1 with a CI body.
The skirt is fibreglass which I painted with car spray paint from a can and it looks fine.
The body side panels are aluminium. I used hammerite 'rollerable' applied with a mini gloss roller which looks OK but a bit orange peely. I haven't tried flattening it back yet.
The roof is fibreglass and I haven't painted this but gave it a clean up with UPVC restorer which has given it a bit of a shine but not removed some faint discolouration.
Watto
Postby cyberchild » Sat Aug 16, 2008 11:33 am
I did this somewhat unusual.
Green and black for camoflage in forest and mountains.
I`m also buying 4 camo tents 2 on each side.
cyberchild
Postby cyberchild » Sat Aug 16, 2008 11:41 am
Oh i almost forget, Notice this is MK2 and that CI motorhome house on the back is from a MK1. Heavy customized.
cyberchild
Postby foggy08 » Sat Aug 16, 2008 1:43 pm
thanks for the advice ,watto ....yours looks smart ill take a leaf from your book and have a go
foggy08
Postby FredTransit » Sat Aug 16, 2008 9:08 pm
Watto wrote:I have a MK1 with a CI body.
The orange peel effect is usually a reaction between two paints. What ever you decide to paint with, try a small area first to see if there is a reaction. If there is, you will need a barrier primer.
FredTransit
Mk2 Trannyist
Postby toriitom » Sat Aug 16, 2008 9:35 pm
FredTransit wrote:The orange peel effect is usually a reaction between two paints. What ever you decide to paint with, try a small area first to see if there is a reaction. If there is, you will need a barrier primer.
Is the orange peel effect not caused by the roller :?: The reaction between two paints is usually more severe causing bubbling and paint lifting :P
toriitom
Postby FredTransit » Sat Aug 16, 2008 9:37 pm
I would say the roller would leave a more very slightly pimply surface, is that what you mean? If so you are right, it should buff out.
FredTransit
Mk2 Trannyist
Postby Watto » Sat Aug 16, 2008 9:55 pm
I don't think there was a reaction with the original paint - that would give a blistering. It's just that the roller doesn't give a truly flat finish. I think the best finish would be obtained from sprayed paint but I don't have the facilities and the roller finish is good enough for me (I'm not looking for perfection) :D
I know paint always looks better in a photo but here is a before and after anyway...
Before....
After....
I haven't done anything with the panels with the windows in yet. I'm unsure about doing it the same colour as the bottom panel as I think this might look to much all the same shade. It currently looks a bit of a bluish white. I thought of trying a can of kitchen appliance paint from Halfords :!: :!:
Any suggestions :?:
Watto
Postby toriitom » Sat Aug 16, 2008 10:13 pm
On the forum somewhere there is a thread about painting with a roller. The paint used was Rustoleum CombiColor. The finish is orange peel but if you require a good finish you can rub it down with wet&dry then polish with body compound. It can be as close to the finish of sprayed paints.
If you do a search you will see it. :P
toriitom
Postby Watto » Sun Aug 17, 2008 9:14 pm
Found that post about painting with a roller. It had a link to this site......
http://wiki.80-90.co.uk/index.php/Body_ ... r_painting
Very interesting. Thanks for the info Toriitom :wink:
Watto
Postby BOLTON WANDERER » Mon Aug 18, 2008 10:20 pm
Watto wrote:I don't think there was a reaction with the original paint - that would give a blistering. It's just that the roller doesn't give a truly flat finish. I think the best finish would be obtained from sprayed paint but I don't have the facilities and the roller finish is good enough for me (I'm not looking for perfection) :D
Before....
After....
Any suggestions :?:
the shiney aluminium pannels on the back will need to be coverd with etch primer first, or the paint, in time, will just flake off.
any car paint shop will sell you this.
trust me on that.
a wise man learns by other's mistakes
a fool learns by his own. :D
IF IT AINT BROKE DONT FIX IT!!
EVERYBODY'S ENTITLED TO MY OPINION
GROWING OLD IS INEVITABLE
GROWING UP IS OPTIONAL
BOLTON WANDERER
Return to Mk 1 & 2
