just had another thought, you said in your post that you havnt used this van for a while, petrol goes bad after a while, it could be crap petrol.
another thing, if it's idling well and reving well, but not pulling through the gears, then it sounds like fuel starvation problems.replace all fuel filters, if you have one of those inline plastic filters, throw it away and fit new.
turn the engine over with the key, disconect the fuel line going into the carb, and check you are getting inuff fuel from the fuel pump, it could be a worn pump.
hope ive helped you.
