mk2 front axle needed. got one at last !
Postby nel2373 » Sat Aug 30, 2008 5:02 pm
anyone got a front axle for a mk2 long wheel base need to upgrade my mk1 landliner from non existant drum brakes to disc do i really need to change the whole front or can mine just be converted ?
nel2373
Re: mk2 front axle needed
Postby Luke » Sat Aug 30, 2008 6:07 pm
whereabouts are you :?:
i think a swb axle can be converted to lwb using just the hubs and also a mk3 lwb set up will fit - if that helps :D
Postby nel2373 » Sat Aug 30, 2008 6:22 pm
hi ya i'm in east london having a nightmare trying to find somewhere to store my van, small workshops cost a fortune . doesn't the mk3 transit have indepndant susspension though or do you just change the hubs ?
nel2373
Postby nel2373 » Sat Aug 30, 2008 6:26 pm
i only said i need a long wheelbase axle because thats what i was told. can i get away with a short wheelbase axle ?
nel2373
Postby FredTransit » Sat Aug 30, 2008 6:27 pm
What van have you got? The Mk3 twin wheel is beam axle too.
Luke wrote:whereabouts are you :?:
Now you tell me! I wish I had known that before I scrapped the one I had the engine out of.
FredTransit
Mk2 Trannyist
Postby Luke » Sat Aug 30, 2008 6:44 pm
no fred that was mk3 swb :lol:
i think mk1/2 swb and lwb beam is the same just the hubs that are different - i think a mk3 lwb is the same too but cant be sure if the hubs will swap :? but i am sure the whole thing will bolt up complete :D
Postby FredTransit » Sat Aug 30, 2008 7:05 pm
OK I thought you meant the hubs off the SWB will fit the Mk2. That's where I am getting confused. Can you just not swap the whole front axle off the LWB/six stud Mk3 onto a Mk2?
FredTransit
Mk2 Trannyist
Postby Luke » Sat Aug 30, 2008 7:45 pm
FredTransit wrote:OK I thought you meant the hubs off the SWB will fit the Mk2.
i didnt mean that but now you mention it i 'think' they will :lol: they are wider by about 3/4" aswell 8)
Postby FredTransit » Sat Aug 30, 2008 7:52 pm
:lol: Well at least you are honest. I would like to give that a try. The hubs have got to be easier to get hold of than a Mk2 front axle.....
FredTransit
Mk2 Trannyist
Postby Luke » Sat Aug 30, 2008 8:42 pm
the other thing is can a drum brake axle be converted to disks by changing the hubs :?: ie are the spigot shafts the same :?:
Postby FredTransit » Sat Aug 30, 2008 8:43 pm
Pass. I wish you had mentioned it before I sent it off though, it wouldn't have cost me much to find out!
FredTransit
Mk2 Trannyist
Postby transitgeoff » Sat Aug 30, 2008 8:43 pm
no mounting points for the calipers :wink:
transitgeoff
Postby Luke » Sat Aug 30, 2008 8:45 pm
transitgeoff wrote:no mounting points for the calipers :wink:
so apart from that they are the same :?: caliper mounts just bolt on 4 bolts if i remember :?
Postby FredTransit » Sat Aug 30, 2008 8:46 pm
Ah well, nice thought while it lasted :lol:
FredTransit
Mk2 Trannyist
Postby transitgeoff » Sat Aug 30, 2008 8:48 pm
no there cast with the stub, no bolts :)
transitgeoff
Return to Mk 1 & 2
