Mk3 Steering on Mk2
Mk3 Steering on Mk2
Postby cyberchild » Tue Sep 16, 2008 12:45 pm
I noticed my steering pole on my mk2 are "dented"
I have plans for using the mk2 Pittman arm, mk2 joint ball, in front and back at the other arm.
I plans to replace my thinner steering pole with a much more powerful mk3 pole. I will also use the mk3 joint balls there too,
I noticed my mk3 pole is a little wider than my mk2, but i will try to make it fit.
this one from mk3
Also this one from mk3 will replace my rotten mk2.
Here is the pole from mk3
Is there anybody here who has done this swap, Will it work?? My steering is pretty rotten as my joint balls are "gone", I have new one from ford.
cyberchild
Re: Mk3 Steering on Mk2
Postby FredTransit » Tue Sep 16, 2008 12:54 pm
Damn Mk2 parts grow on trees where you are! Do you have a window winder bush anywhere near you?
FredTransit
Mk2 Trannyist
Postby wardy-uk » Tue Sep 16, 2008 2:15 pm
FredTransit wrote:Damn Mk2 parts grow on trees where you are! Do you have a window winder bush anywhere near you?
:lol: :lol: :lol:
wardy-uk
Postby Gunslinger » Tue Sep 16, 2008 2:32 pm
:lol: :roll: :mrgreen:
as well as laughing, i'm also intrigued by the "mix-n-match" of parts here, so i'll keep an eye on your progress with interest
Gunslinger
Postby davek » Tue Sep 16, 2008 5:37 pm
I looked in to mix and match mk2/3 when i did the pas convertion - in the end put everything from mk3 on - from the steering wheel to the beam/hubs
davek
Postby Luke » Tue Sep 16, 2008 5:39 pm
the mk3 arm is a different size taper to the mk2 one :!: :D but if you are fitting the complete lot i think it should go on :)
Postby jnwferguson » Tue Sep 16, 2008 7:55 pm
isnt the mk3 wider than mk2 axle ?if so the parts wont fit will they
cheers jim.
mk2 lwb 4x4
mk2 lwb camper
mk2 ci travelhome camper
the devil is in the detail
jnwferguson
Postby davek » Tue Sep 16, 2008 8:55 pm
I was told my beam was off a 90 mini bus it fitted my v reg mk2 -boltted straight on the springs only mod was mounting the pas steering box
davek
Postby Gunslinger » Tue Sep 16, 2008 9:34 pm
the steering bar that goes across the van from one side ot the other is longer on the mk3 than the mk2 (i know cause i've got a brand new one :P )... if i remember correctly it's about an inch longer, but dont hold me on that
Gunslinger
Postby cyberchild » Tue Sep 16, 2008 11:49 pm
i`m sorry, no windows busher here. :)
I know the bar is one inch or less longer, but i see on the tightening on the rose joints. you can adjust it to fit just screw them longer into. Tomorrow i will see if its fits as plans...
I have a steering box from a mk3, But the pole that goes from the box to the steering wheel was to short. and 3 screws hole in the torpedo wall. or else i could have used the ignition key and light switches. as my old one broke down on me...
to be continued...
cyberchild
Postby cyberchild » Wed Sep 17, 2008 1:35 pm
I screw the Joint balls more into the pole. One links and one regular.
IT FIT`s my mk2 !!!!!!!! :D
But just, had it been .... 5-10mm wider i could not swap that wider mk3 steering pole...
This pole from a mk3 is much powerful than the thin mk2 pole.
Today it`s raining like sh*t. Heard that the storm "ike" is on the way to make our transit`s wet..
But this seems like working !!!!
JOHOOO !!! :D :D :D
cyberchild
Postby Gunslinger » Wed Sep 17, 2008 9:19 pm
interesting, thank you for the info.... i was under the impression that the mk3 ball joints/drag link ends were of a different thread pitch to the mk2 ones.... so i didnt know if the nk2 ones would fit the mk3 pole
Gunslinger
Postby cyberchild » Thu Oct 02, 2008 4:41 pm
After days of pouring rain of destruction.
i take of the old mk2 bits and replace it with some mk3 parts.
The mk3 pittman`s arm is more durable, seems more powerful. my old mk2 pittman seems bendt somehow... and rusty....
But when the pittman`s arm is off the steering box, i feel some "slack" in the steringbox, I will adjust the tightening screw. Anyone know what oil i shall fill on my mk2 steering box??? and how much????
The mk3 steering pole. is 1" wider than the mk2... But it fits just fine, just adjust the bolts longer into the middle...
The mk3 hubs in front are much wider than the mk2 aswell. so the steering from a mk3 with these poles and stuff, will fit just fine.
i use 2 rose joints from mk2 at the pittmans arm and at the back.. and i use 2 rose joints at the steering pole from mk3.
Seems like everything goes well....
cyberchild
Postby Luke » Thu Oct 02, 2008 6:46 pm
i'm slightly confused with all the terminoligy etc. but .........................
is the mk2 axle king pin to king pin the same or different to the mk3 one :?:
Postby cyberchild » Sat Oct 04, 2008 10:52 am
eeh... I did not use the mk3 kingpin. Did not have the right tools. But then i tried mk2-mk3 swap, i just used the front hub 6studs from a mk3. fitted just fine. become a little bit wider at the front, but thats ok. A little misunderstanding from ford dealer makes me on a hold. waiting for the right bits and parts...
cyberchild
Return to Mk 1 & 2
