mk1/2 rear axle
mk1/2 rear axle
Postby tb2 » Mon Jan 16, 2006 5:30 pm
hi
will a mk1 twin wheeler rear axle fit a mk2 twin wheeler thank you for any help in this matter ian
tb2
Postby FredTransit » Mon Jan 16, 2006 11:20 pm
I would say yes, anybody know otherwise?
FredTransit
Mk2 Trannyist
Postby Luke » Mon Jan 16, 2006 11:52 pm
the only thing im aware of thats different between the mk1 and the mk2 chassis is the bush sizes!
Postby Gunslinger » Tue Jan 17, 2006 5:03 pm
agreed, there is nothing i know of to stop you swapping the whole axle over, input flange and mountings should be the same, watch your ratios though
Gunslinger
thanks
Postby tb2 » Tue Jan 17, 2006 11:29 pm
thanks
tb2
Postby Rolo » Fri Mar 03, 2006 2:29 am
Gunslinger wrote:agreed, there is nothing i know of to stop you swapping the whole axle over, input flange and mountings should be the same, watch your ratios though
I own a Mark 1 and I believe the difference with the Mark 2 is that the Mark 1 has the spring "saddles" (the metal where the springs bolt to the axle) on the top part of the axle to accommodate its much shorter springs and the lack of a rear shuckle.
The Mark 1 rear springs just slide on bare metal, dump truck style.
Are the Mark 1's different in the U.K.?
1973 drw; Falcon 250 c.i.; 12v fuel pump; belt-driven water pump & fan replaced with 12v water pump & two 12" fans; T5 gearbox; Mark II front discs.
Rolo
Postby Gunslinger » Fri Mar 03, 2006 9:59 am
sounds like it, my mk2 has those saddles you are talking about on the top too, effectively for those trying to picture this :P .... the spring presses down on top of the axle, rather than the spring being routed underneath the axle
Gunslinger
Postby Rolo » Fri Mar 03, 2006 12:29 pm
Gunslinger wrote:sounds like it, my mk2 has those saddles you are talking about on the top too, effectively for those trying to picture this :P .... the spring presses down on top of the axle, rather than the spring being routed underneath the axle
I thought the only reason for that type of spring mount was because of the lack of a rear shackle in the Mark 1 spring.
When were the slipper springs discontinued in the U.K.?
Rolo
Postby Gunslinger » Fri Mar 03, 2006 1:37 pm
i am going to have to try and find you a picture because i am not convinced we are talking about the same thing here
Gunslinger
Postby Rolo » Sat Mar 04, 2006 7:24 am
Does your Mark 2 have a shackle at the rear of the spring, the same as the rear of the front springs?
If it does and the springs are mounted on the top of the axles I would definitely want to see it since the only purpose I can think of for that would be to gain extra ground clearance and I'm yet to find a Transit designed for anything other than paved roads.
Rolo
Postby Gunslinger » Sat Mar 04, 2006 12:11 pm
Yes ..... in essence, it has a pin at the front which allows it to pivot up and down at the front, and a shackle at the back which allows a small amount of front to rear travel, this i believe is standard on mk2's over here, as for pictures of mine, not possible at the moment as i don't have a digital camera, but i might be able to rustle something up from the workshop manual i uploaded and posted the link to on this board
Gunslinger
Postby Rolo » Mon Mar 06, 2006 8:45 am
The only way I can visualize a Transit with the springs mounted on top of the axle and with rear shackles is for the springs to be almost flat... unless the rear shackle is mounted much higher but that would be imposible in the Mark 2s I have seen up to now.
Rolo
Postby Gunslinger » Mon Mar 06, 2006 10:29 pm
download this and take a look through the pictures
http://rapidshare.de/files/14867680/Rear_Axle.pdf.html
Gunslinger
Postby Rolo » Fri Mar 10, 2006 3:01 am
Gunslinger wrote:download this and take a look through the pictures
I have seen your post and I haven't acknowledged it yet because I'm still dealing with some greyware problems trying to see those pictures.
Today I'll get one of my kids to open it for me.
Rolo
Postby Gunslinger » Tue Mar 21, 2006 1:28 pm
no problem, ive been kinda busy with other stuff lately and not here much myself
Gunslinger
Return to Mk 1 & 2
