get this bit if you can it will fit your floor perfectly, i know you cant weld but you could at a push bond and pop rivit it in - or get someone else to weld it for youmike c wrote:I'm not in a hurry to do the conversion, hence wanting to know which bits are most ideal, just planning ahead for a more robust gearbox
Luke wrote:another thing .......... is it the same starter motor![]()
or do you need a different one as its now mounted on the plate
not sure mabe someone will know
rover wrote:Its easier to just cut a hole in the floor dont you think Luke? Fine if you can weld but I wouldnt fancy just rivetting a large piece like that in![]()
Rover.
rover wrote:I've got one here sitting on my scrap pile if you want it? (Nottingham)
Also the front half of the prop should be fine and join it to your rear half... I've got that too![]()
If you want them and can fetch them they are yours for nowt.
Rover.
mike c wrote:rover wrote:I've got one here sitting on my scrap pile if you want it? (Nottingham)
Rover.
you legend, i'm only down in hinckley so nottingham isn't far, i'd be only too happy to take the bits off your hands for some beer tokensif an evening is good i can get there for 6pm, otherwise it'll have to be friday afternoon or sunday.
i was planning on just cutting the floor and seeing how that goes, a welder is on the cards in the not too distant hopefully so i can also go back and do that later if i want. i definately dont want to be riveting in panels, smacks of bodgery!
thanks everyone..... this seems to be easier than i thought!
captain - i have already gone through one 4 speeder (was already damaged when i got the van). The MT75 is a very well designed gearbox and far more modern than the type G. If it goes i'll struggle to find a good replacement, whereas there are loads of MT75's about. I hate knowing i've got an outdated, heavy, horrendously noisy bit of kit under me when a much better part can be fitted pretty easily and cheaply. I think you might have had some bad luck with mt's and good luck with the type G - it might well be suited to heavy loads but not so much high speeds.
cheers
Mike
