Mk2 vented discs
Mk2 vented discs
Postby bortaf » Sun Jan 29, 2006 1:10 am
Will the vented discs and calipers from the Mk3 fit?
the Mk2 ones are a wee bit warped (still the best brakes of any motor i have but the peddel has started to pulse when i brake lightly.
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby FredTransit » Mon Jan 30, 2006 10:46 am
Not at all sure, is it an early Mk3? How hard would it be to do the whole axle?
FredTransit
Mk2 Trannyist
Postby Gunslinger » Mon Jan 30, 2006 4:23 pm
replacement mk2 discs are readily available from any motor factor and are not so expensive, also the calipers i got were not meant for the vented discs i have, however the calipers were exactly the same, apart from a spacer fitted between the 2 halves, so if you can get a set for the solid discs cheaper then just check the model numbers and if the same, simply add the spacer :D (remembering to use the original bolts of course as they are longer !)
Gunslinger
Postby bortaf » Mon Jan 30, 2006 11:24 pm
They are on the L reg ,it's just that they are new discs and pads and vented, think i'll take em off anyhoo :D
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Gunslinger » Tue Jan 31, 2006 2:48 am
Gunslinger
Postby Gunslinger » Tue Jan 31, 2006 2:56 am
and here's one caliper .... dont ask me, i have no idea how you end up with only one :lol:
http://cgi.ebay.co.uk/BRAND-NEW-GENUINE-BRAKE-CALIPER-FORD-TRANSIT-MK2_W0QQitemZ4607448971QQcategoryZ21654QQrdZ1QQcmdZViewItem
i'm sure another one will come along eventually :P
Gunslinger
Postby bortaf » Tue Jan 31, 2006 2:43 pm
Me M2 has 2 pot non vented at the mo, just thought the later ones would be a cheep upgrade :)
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Sundowner » Wed Feb 01, 2006 6:27 am
Hey bortaf if your running the std 5 stud mk2 hubs the dicsc and calipers wont fit
The vented disc will bolt to the 5 stud hub but the caliper will hit on the outer hub
Sundowner
Postby bortaf » Wed Feb 01, 2006 7:35 pm
yeh mate they're both 5 stud wheels :)
ah well one more thing to go on ebay :lol:
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Return to Mk 1 & 2
