The type 9 apparantly not!! but you will need to swap from the o/d one i think!! MT75 yes!!MrMPuk wrote:Would that then also require a custom propshaft?
24vMk2 wrote:Which parts are you having trouble getting hold of?
I find them fairly easy, just need to know where to look.
Luke wrote:pinto and essex are different bellhousing pattens but the 4speed + o/d box should fit with an essex bellhousing i think
mk2 transit used an adapter plate to the gearbox - i think to allow a bigger flywheel - i cant think of any other reason!24vMk2 wrote:Surely ford wouldn't used an adapter if they had 2 different bell housings.
