Oil seal: MK1 Gearbox Tail-Shaft
Postby MK1Chris » Tue Dec 02, 2008 1:28 pm
I need to replace the oil seal that seals the tail of the gearbox with the input from the prop-shaft (apologies for not knowing what it's technical name is :oops: ).
It's from a SWB MK1 transit with the original 4 speed gearbox (NOT overdrive) and original propshaft.
Does anybody know what the part number is, or even better - where to get one from?
Thanks :wink:
MK1 CI Motorhome.
Original 2Litre V4 and 4 Speed Manual with 29k on the clock (now up to 31k!)
Rusty problems soon to be sorted. See my progress in the projects section... http://fordtransit.org/forum/viewtopic.php?f=27&t=28696
MK1Chris
Re: Oil seal: MK1 Gearbox Tail-Shaft
Postby sapper 514 » Wed Dec 03, 2008 3:08 pm
Hi I had the same problem recently,had good advice from Rover,he suggested looking in yellow pages for a local gearbox repair Co.Did that they had the proper seal in stock £3.50 job done.
sapper 514
Postby redeemer » Thu Dec 04, 2008 9:55 pm
http://www.transmission-rebuild-kits.co ... 82a447d55b
have a look there
If you are able of doing the job yourself just order theoil seal you want as I have did.
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Return to Mk 1 & 2
