MK 3/4/(5?) MT75 gearboxcrossmember in MK1 Transit.
Postby cartooner » Tue Jan 20, 2009 6:03 pm
Hi, I'm still in the process of fitting a 2.9V6+MT75 from a 1994 Granada/Scorpio into my MK1.(see other topic). One of the things I need is another crossmember to support the MT75 gearbox in the MK1. I found this one on a salvage yard:
Can anybody tell me if this is the correct one. It is said to have come from a 1994 Transit with a MT75 gearbox. A quick look and trial fit under the MK1 made me think it will work.
thx
cartooner
Re: Can You identify my member?
Postby Luke » Tue Jan 20, 2009 6:09 pm
cartooner wrote:It is said to have come from a 1994 Transit with a MT75 gearbox.
yes it has :D
the mounts are the same distance apart but they may need adapting to fit the mk1 as the rear spring hanger is in the way :D
also remember its handed - ie the mount is not central :!: :idea: :D
Postby cartooner » Tue Jan 20, 2009 7:06 pm
Cheers Luke, Yes indeed it is handed. It seemed a bit akward at first, the original crossmember must be handed too. Didn't pay attention to that. This made me doubt at the breakers. Glad I took it with me though. One step further.
cartooner
Postby Luke » Tue Jan 20, 2009 7:09 pm
yes the engine mounts are not central either - the enigne is in line but offset to match to the back axle :D
Postby redeemer » Wed Jan 21, 2009 6:12 pm
yes it has :D
So luke the gearbox is mounted a bit on one side , is that what you r telling?
I have never noticed that! Maybe should take a look at mine's because the van vibrates a little even after a gearbox rebuilt!! But from what I remember it got in straight with no trouble!!!
Cartooner that the right member as luke said, but need to modify the ends, maybe will be easier to use the ends off the current member you have there.
good luck!
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Postby Luke » Wed Jan 21, 2009 6:35 pm
redeemer wrote:So luke the gearbox is mounted a bit on one side , is that what you r telling?
yes mate :D the engine and box are not central - they are in line with van just a few inches to the drivers side :D
Mk3/4/(5?) MT75 gearboxcrossmember in MK1 Transit.
Postby cartooner » Thu Jan 22, 2009 1:45 pm
Thx guys, I already fixed it. Had to cut 1/2 inch of the mounts that face the back of the car, to get the crossmember enough backwards against the rear frontspringhangers for the front holes to line up with the existing holes in the framerails( mountholes only needed minor opening up to fit exacly). Than I had to drill new holes for the rear mounts and make small holes on the sides of the framerails( Dremel multitool with small cutting blade) to make it possible to insert a bolt and washer from the side and hold those with a spanner. Et Volia it's in. Hope this make sense for people who want to try this too. Will post pics when the weather clears.
cartooner
Return to Mk 1 & 2
