Front Bumper
Front Bumper
Postby 214si » Tue Jan 20, 2009 8:48 pm
where does it bolt onto lol???
does it go throught the slam panel?? or through the lower front valance???
i aint put her together yet and was just wondering what holds it in place as the brackets on the back of the bumper have a stepped plate with a thread on it but i cant see where it would bolt in place :lol:
214si
Re: Front Bumper
Postby welshrussell » Tue Jan 20, 2009 10:50 pm
Have a look at mine :D
You can see the black threaded holes where a bolt goes - this is what the v shaped bracket goes into that holds onto my chrome bumper.
Hope this helps :?:
Do good things - and good things will happen to you!
welshrussell
Re: Front Bumper
Postby Luke » Tue Jan 20, 2009 10:52 pm
214si wrote:where does it bolt onto lol???
mk1 or mk2 :?:
Re: Front Bumper
Postby 214si » Tue Jan 20, 2009 11:03 pm
sorry mk2!
214si
Re: Front Bumper
Postby Luke » Tue Jan 20, 2009 11:11 pm
mk2 bolts through the front panel onto some angle brackets which bolt onto the front crossmember :D
Re: Front Bumper
Postby 214si » Wed Jan 21, 2009 1:51 pm
bugger i dont have these angled brackets off the crossmember!!!
off i go :D
214si
Re: Front Bumper
Postby vana mana » Wed Jan 21, 2009 2:04 pm
you should have..did i not give you any with the bumper?
vana mana
Re: Front Bumper
Postby 214si » Wed Jan 21, 2009 4:28 pm
yes, the brackets are there on the bumper itself, i dont have the brackets from the front crossmember in which the bumper would bolt onto
214si
Re: Front Bumper
Postby redeemer » Wed Jan 21, 2009 6:01 pm
is it a phase 1 or 2 that is a steel grille or plastic grille ,
because the the phase1 has an angle bolted to the front cross member and this bolts to the flange of the bumber
but the phase2 have a larger hole in the on the front so the bumper bracket goes through and bolt directly to the top face of the chasis rail.
hope it helps. :D
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Re: Front Bumper
Postby vana mana » Wed Jan 21, 2009 6:06 pm
Now im getting confused..the one i had was pre facelift..i will look for brackets ..not sure if i still have em..there yours if i can find em/may have gone with bus to scrappy..may have spares..
As for plastic grill mk2 i will have to check my mates for set up..i thought they were all the same fixings :?
vana mana
Re: Front Bumper
Postby 214si » Thu Jan 22, 2009 10:54 am
not a big problem i sure i can knock some kind of bracket up to hold it in place!
214si
Re: Front Bumper
Postby vana mana » Thu Jan 22, 2009 7:23 pm
i will still have a look for ya..
vana mana
Return to Mk 1 & 2
