leaf springs
leaf springs
Postby madbri » Fri Jan 23, 2009 11:25 pm
hi new member madbri here.You have probably been asked this question a thousand time before but can anyone tell me do the mk3 leaf springs front and rear fit on to a mk2. Many thanks.
madbri
Re: leaf springs
Postby Luke » Fri Jan 23, 2009 11:31 pm
the fronts will :D
what is the mk2 :?: swb lwb chassis cab etc :?:
Re: leaf springs
Postby madbri » Fri Jan 23, 2009 11:42 pm
Luke wrote:the fronts will :D
its a mk2 swb ci campervan
madbri
Re: leaf springs
Postby Luke » Fri Jan 23, 2009 11:46 pm
pritty sure the backs will if they are off a swb :? but the fronts definatly do but mk3 lwb only of course as swb were coils :D
Re: leaf springs
Postby madbri » Fri Jan 23, 2009 11:56 pm
Luke wrote:pritty sure the backs will if they are off a swb :? but the fronts definatly do but mk3 lwb only of course as swb were coils :D
many thanks :D
madbri
Re: leaf springs
Postby hodgson4711 » Sun Jan 25, 2009 3:28 am
i fitted front springs of a mk3 onto my mk2 no problem at all. fit new bushes.
hodgson4711
Re: leaf springs
Postby cyberchild » Mon Jan 26, 2009 6:42 pm
I also have my mk2... and i wonder ????? The U-Bolts that holds the Front Mk3 Swb Leafs are much wider... they will not fit unless you use the old mk2 U-Bolts... they are much smaller and thinner....
cyberchild
Return to Mk 1 & 2
