Pinion Oil Seal - £40! How Much?
Postby Southerner » Wed Feb 04, 2009 1:14 pm
I'm having problems sourcing a new pinion oil seal for my van. 1971 SWB (90) Diesel Mini-bus.
I took the diff down to the local Ford garage and asked them to replace it, I assured them that you could still get hold of a new seal (I think someone on here said they still made them). Apparently not the case. The garage gets a seal in but this doesn't fit. Apparently nobody round here seems to have the microfiche to get the part number, so I phoned up a parts place that I knew had the microfiche and got a part number - 1709-662. During which time my old seal has been removed and sent over to the local parts place to play snap with what stock they have left. Spent the day phoning round to find one myself and have been told: The axle is the Timken type, not English. These seals are no longer made. The only palce I have found one is through Bearingkits via a special order and this is going to cost me £40!
:? So my question's are:
1) Anyone know whether 1709-662 is the real part number (this may help)
2) What sort of axle I have - Timken or English? Didn;t the escorts have timkens?
3) Where I can get a seal for less than £40 - you can pick an english axle pinion oil seal up for £6
Any help greatly appreciated.
Cheers, Andy.
Southerner
Re: Pinion Oil Seal - £40! How Much?
Postby madmark » Wed Feb 04, 2009 2:42 pm
andy is there any numbers attal on the seal????????
Postby Southerner » Wed Feb 04, 2009 4:01 pm
No Mark, there's not unfortunately - that would have been handy!
Southerner
Postby Luke » Wed Feb 04, 2009 6:08 pm
it was me who said you can still get them you just need the ford part number :D and 1709-662 isnt it :(
Postby Chaz&Saz » Wed Feb 04, 2009 6:43 pm
When fitting a different trumpet to a 3 rail gearbox (cortina) i found i needed a special seal due to differences in input shafts/trumpets, i just phoned my local bearing supplier and gave them the dimensions of what i wanted and they sent me one. We get all our hub oil seals from them too so they should be able to help. Pm me and i will give you there number.
Charlie
1972 Built, 1973 Registered, Land Liner V6
1967 Triumph Herald - Bethany
1976 Triumph Dolomite
Chaz&Saz
Postby Southerner » Wed Feb 04, 2009 7:26 pm
Thanks guys - I'll get on to my garage again then - last time they were telling me there should be four more numbers to the part, if they can't help I'll give the parts people a bell direct, if that's no good I'll drop you a line Charlie. Cheers, Andy.
Southerner
Postby madmark » Wed Feb 04, 2009 8:02 pm
if you can get the old one out there is a good chance it can be matched! :wink:
Postby Southerner » Thu Feb 05, 2009 11:57 am
After all that they have found a part and will be fitting it today, I'll let you know how much it was etc when I pick it up. Cheers, Andy.
Southerner
Postby madmark » Thu Feb 05, 2009 12:10 pm
8) well done mate! :wink:
Postby MK1Chris » Fri Feb 06, 2009 6:09 pm
I'm after one of those as well.
1978 SWB single wheel axle.
It sounds like your axle will be the same as mine, so when you find the details, could you post them up here.
Thanks,
Chris
MK1 CI Motorhome.
Original 2Litre V4 and 4 Speed Manual with 29k on the clock (now up to 31k!)
Rusty problems soon to be sorted. See my progress in the projects section... http://fordtransit.org/forum/viewtopic.php?f=27&t=28696
MK1Chris
Postby Southerner » Mon Feb 09, 2009 6:21 pm
Success! Part number was 1709 662, £9.49, much more like it! Diff all ready to go back on. :D Cheers, Andy.
Southerner
Postby bron y aur » Mon Feb 09, 2009 8:09 pm
:roll: , In that case il nip round to Wilko's tomorrow and see if they've got one :evil:
i started with nothing, still have most of it left
bron y aur
Postby Trinny » Sat Feb 14, 2009 5:31 pm
Where did you get the correct seal from?, does it give suitability for other Fords/any other models on the packaging?
Trinny
Postby Southerner » Sat Feb 14, 2009 9:03 pm
Got it from Fords, FINIS code 1709 662. :D The bloke couldn't tell me whether they still made them but after all my panicking they dug one out no problem. No idea on what other models it would fit. Cheers, Andy.
Southerner
Postby Trinny » Sat Feb 14, 2009 9:49 pm
So the part no. was right,
thanks for the info.
Trinny
Return to Mk 1 & 2
