MK1 Chassis
MK1 Chassis
Postby lutonwayne » Tue Apr 12, 2005 7:29 pm
Does any one know if the chassis legs and crossmember on MK1 transists are the same as on MK2
lutonwayne
Postby Luke » Tue Apr 12, 2005 7:32 pm
Welcome Wayne!!! :D
and im 99% sure they are but someone will correct me if im wrong :oops:
Postby FredTransit » Tue Apr 12, 2005 10:07 pm
I have never compared the two, but Ford Being Ford I am also 99% sure that they are. Ford just are too tight to design a completely new chassis for the two. I could be wrong, but my theory is that the two transits are the same from the bulkhead back, save for a few cosmetic differences like door handles.
BTW, welcome Wayne, got this clue from your ID, have you got a Mk1 luton then?
FredTransit
Mk2 Trannyist
Postby Gunslinger » Wed Apr 13, 2005 2:08 am
it depends how far back you go, i can't fully confirm that the step the crossmember blots to is the same dimensions on a mk 1 as 2
and i am fairly sure the rear spring hangers have different box section fittings around them
Gunslinger
Postby Luke » Wed Apr 13, 2005 12:36 pm
Gunslinger wrote:and i am fairly sure the rear spring hangers have different box section fittings around them
Yes!! the mk1 and mk2 have a different bush in the spring hanger, The mk2 is bigger!!! but its interchangable!! :D
Return to Mk 1 & 2
