mk1 swb camper rear wheel space
Postby walker tranny » Tue Feb 24, 2009 6:55 pm
hi l just fit out my mk1 swb as a camper now the rear wheel arces have drop you can just get your fingers under them what should be the right space be ie in inch and would l need to put a extra leaf spring in or replaces the shockers thanks steve :idea: :idea: :idea: :idea:
walker tranny
Re: mk1 swb camper rear wheel space
Postby redeemer » Wed Feb 25, 2009 3:21 pm
IF you want to put up the van again , if you are going to load it a lot , the I suggest you add a helper leaf, and sometimes here they put spacer bloks of solid steel between the bottom of springs and the axle. Also then you would be needing longer U bolts as the thread will finish .
The shockers have nothing to do with the height , they are there just to absorb the energy and dapens the effect of the springs.
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Postby walker tranny » Thu Feb 26, 2009 8:33 pm
are mk5 rear spring hangers larger then mk1 spring hangers ie from the rear chassis to the leaf spring thanks steve
walker tranny
Postby redeemer » Thu Feb 26, 2009 10:50 pm
Don't know that about mk5's but leave for the profss to come... :lol:
WHat I know for sure is that the mk2 facelift(plastic grille) was updated to a much larger tapered bushes on the rear and longer connections beteween the chasis and the end of spring.
redeemer
Return to Mk 1 & 2
