Well yest I have replaced the temp sensor to a one which I removed off an early 2.5di , before I fitted it I cheked it with the ohm meter , and it varied as I put a small lighter flame to it. The gauge now is working and after about 15/20mins running, it marks that the engine is at a high temp.
Is the sensor the right one for my application? I assume it is, since the electronics (voltage regulator and sensor) are both off the mk2.
Or maybe I have to check out the termostat ? It isn't any older than a year..
Have read here that mk2 gauges have a tendency to mark on the cool position
