Which fuel pump and air filter for my MK1?
Postby welshrussell » Mon Mar 02, 2009 11:02 pm
Justing posting a question about the best sort of fuel pump for my 2 litre V4 :?:
Currently I've got the glass bowl variety but heard rumours it might be vulnerable to fuel evaporation - but I do talk a lot of crap :lol:
If I were to change it, what are the pros and cons of other sorts of fuel pumps.
Also I just won this air filter box on ebay
It was listed as for a Ford V6 (Capri) but do you think it will go onto the top of my twin Weber (with a bit of modification) :?:
All suggestions gratefully received :D
Cheers
Russell.
welshrussell
Re: Which fuel pump and air filter for my MK1?
Postby madmark » Tue Mar 03, 2009 6:40 am
:? the glass bowl type was used on erly v4 engines ,maybe change to the later type but i cant see you would gain much myself!
the airfliter houseing i cant see fitting mate! you will probly need a pan from a corsiar! or use the transit one and cut the weber shape out in the bottom to fit! :wink:
Postby baconsdozen » Tue Mar 03, 2009 9:30 am
I prefer the older glass topped pumps as you can see whats happening to the fuel,other than that there's nothing to chose between them.
baconsdozen
Postby welshrussell » Tue Mar 03, 2009 7:48 pm
Cheers guys,
When it arrives I'll take a look and see what I can do :?
Do good things - and good things will happen to you!
welshrussell
Postby Neil » Tue Mar 03, 2009 8:06 pm
fit an electric pump :wink:
Neil v6
Neil
Return to Mk 1 & 2
