Wipers blowing fuse
Wipers blowing fuse
Postby 3 Way Tranny Fun » Wed Mar 04, 2009 8:34 pm
I have just got a lights/wiper switch from a local breakers,in intermitant postion it blows the fuse and washer dosn't work (I'm sure I can fault find trace washer) any ideas?to save me effing about and head scratching.
W reg Turbo 100
V reg 100 swb
C reg mk2 recovery
R reg 190
3 Way Tranny Fun
Re: Wipers blowing fuse
Postby Luke » Wed Mar 04, 2009 10:21 pm
were they both the same year :?: i can only think there's been a wiring change or mabe it's the relay :? did it work intermittent before you swapped the switch and why did you swap the switch :?:
Postby 3 Way Tranny Fun » Thu Mar 05, 2009 5:45 pm
Swapped switch due to old one doing nothing,tried a mk3 one (cause plugs the same) and that blew the fuse on intermitant I thought that was down to different wireing!
W reg Turbo 100
V reg 100 swb
C reg mk2 recovery
R reg 190
3 Way Tranny Fun
Postby Luke » Thu Mar 05, 2009 6:15 pm
i'm pritty sure a mk3 one is ok - ive fitted a mk3 switch onto a mk2 loom and i only needed to do 1 mod - linking a wire somewhere, cant rememebr what it was for :? but i got no fuse blowing problems :!:
i'd need to look at a drawing but i think there is a relay unique to the intermittent - i'd look at that 1st :D
i'll see if ive got any drawings :)
Postby 3 Way Tranny Fun » Thu Mar 05, 2009 6:50 pm
Its all clear now mines standard not custom,so no intermitant hence fuse blow when switched to that position.My old one only 2 positions.Didn't work that out meself,thanks Fred.Learn something new every day!
W reg Turbo 100
V reg 100 swb
C reg mk2 recovery
R reg 190
3 Way Tranny Fun
Return to Mk 1 & 2
