how do you tell the difference between a mk1 and mk2 axle?
Postby Luke » Sun Mar 05, 2006 9:06 pm
how do you tell the difference between a SWB mk1 and mk2 axle :?:
i know the diff input flange is different but ive descovered this will swap, im now thinking my mk1 has a mk2 axle in it :? just seems to be identical to the mk2 axle i have :? or were they identical :?:
what about the wheel studs/nuts were they imperial on the mk1's :?:
Re: how do you tell the difference between a mk1 and mk2 axl
Postby Rolo » Mon Mar 06, 2006 8:34 am
Luke wrote:what about the wheel studs/nuts were they imperial on the mk1's :?:
My Mark 1 was made before Australia converted to metric in the 70s; didn't the U.K. convert to metric at the same time?
1973 drw; Falcon 250 c.i.; 12v fuel pump; belt-driven water pump & fan replaced with 12v water pump & two 12" fans; T5 gearbox; Mark II front discs.
Rolo
Postby Rolo » Thu Mar 16, 2006 6:00 am
Luke wrote:how do you tell the difference between a SWB mk1 and mk2 axle :?:
One of the differences I have noticed is that the brake shoes in the Mark 2 are wider, which is in good part why I want to update my Mark 1 rear axle.
OOPS!!! Disregard that; only now I noticed that you said "SWB" and my mind is still on dual rear wheel axles,.. but it might still be the same difference with them since Mark 2's have front disc brakes.
Rolo
Return to Mk 1 & 2
