hi guys this is my first post i have a mk1 transit, with a crossflow in it, fourspeed box with a pto coming off it, and i have a crap clutch, loads of travel then a heavyish pedal for the last 2-3 inches, with it running if you lift the clutch it sharply bites straight away, and only works in the last 2-3 inches, it has a hydrolic clutch set up, ive fitted new master cyl and repair kit to slave, still the same it has a rod to adjust to slave cly to clutch fork throw, ive tried this both ways still the same, so im thinking a clutch kit next, but ive never seen another mk1 with hydrolic set up ? so i was wondering if anyone had any thoughts is there any faults with the clutch forks ?? has this been an alteration when they did the pto conversion, this was done from new so couldnt have been this way for the past 30 odd years surley
