sierra engines 1.6 and 2.0
Postby Ed mk1 '66 » Fri Jul 31, 2009 9:09 pm
Hi there,
question1:
My '66 mk1 has a v4 1.6l petrol engine that has been modified to run on LPG. It's a cologne type. I believe that's the same engine as what some people refer to as the 'Sierra engine', am I right?
question2:
I'm would like to switch to a 2.0l. I read in the workshop manual that the only difference between the 1.6l and 2.0l cologne-type engine is the depth of the cylinders (that's probably not the right technical term, but I'm from Holland, so excuse me for my poor technical English).
So, if I'm right on question 1, I guess I could try and find a 2.0l sierra engine and put my own cylinder heads (which are now on my 1.6l and are modified for LPG) on top of that on. Am I right? That would safe me some money on modifying the 2.0l engine to LPG.
Cheers Ed
Ed mk1 '66
Re: sierra engines 1.6 and 2.0
Postby Luke » Fri Jul 31, 2009 9:11 pm
Ed mk1 '66 wrote: I believe that's the same engine as what some people refer to as the 'Sierra engine', am I right?
no it's not :) well not over here anyway :D
sierras have the V6 2.8 and 2.9 cologne which is basically the same engine with another 2 cylinders on the front :D
Postby Luke » Fri Jul 31, 2009 9:13 pm
the sierra 1.6 is the inline 4 known as a pinto - totally different to a cologne V4 :D
Postby Luke » Fri Jul 31, 2009 9:17 pm
i understand the problem you have - i've got a firevan 1.7 cologne V4 too but for us over here we can swap to the 2.0V4 essex engine but for you it's tricky as they were not available - over here the 1.7V4 cologne was not available either :D
the engine you have is either a 1.5V4 or a 1.7V4 - you have the bigest one :lol:
you can fit a 2.0 sierra pinto but you'll have to either fit a bull nose front or squash it under the flat front - it will 'just' go :D
if you can get hold of a bull nose front and bonnet that is the easyest way :D
Postby Ed mk1 '66 » Fri Jul 31, 2009 9:41 pm
I can get a 2.0l essex here in Holland, but I heard they won't do the job very well on LPG, any experience with that?
Ed mk1 '66
Postby Luke » Fri Jul 31, 2009 9:45 pm
there was a guy on here (zein49) he had a mk1 V4 essex on LPG but he did have a lot of trouble getting it to run well :(
Postby Ed mk1 '66 » Fri Jul 31, 2009 9:50 pm
Hmm, I'm in doubt now; how exactly can I see whether I've got a essex or cologne type?
I understand I should look either for a 2.0l OHC Pinto (which will only just fit) or a 2.0l essex, I presume the heads from a cologne typ won't fit on an essex?
I guess putting in a 2.8 cologne V6 behind a bullnose would probably kill my diff, would it?
Ed mk1 '66
Postby Luke » Fri Jul 31, 2009 9:56 pm
can you get hold of a bull nose front :?: or do you want to keep the flat front :?:
does your engine look like this :?: this is mine 1.7V4 cologne
not very good pics but the best i've got :D
Postby Luke » Fri Jul 31, 2009 10:02 pm
Ed mk1 '66 wrote:I guess putting in a 2.8 cologne V6 behind a bullnose would probably kill my diff, would it?
well the diff should be ok as they are strong but the problem you will have is if it is origanal it has a 5.8:1 ratio so with a V6 you'll be needing a 4.63:1 to make full use of the power
like changing up a gear :lol:
Postby Ed mk1 '66 » Fri Jul 31, 2009 10:11 pm
Ok, one problem solved: it's definately a 1.7 cologne, according to your pictures, thanks for that.
I'm OK with changing my nose to a bullnose, I actually quite like the looks of a mk1 with bullnose. They only seem to be pretty hard to find.
My diff has already been modified, but I'm not sure yet what the ratio is at the moment. The previous owner couldn't tell me exactly, he only knew that it was modified, but not to what ratio. how can I check this?
What about a 2.6l HC engine from a Taunus 26M, I can get hold of one.
Ed mk1 '66
Postby Luke » Fri Jul 31, 2009 10:23 pm
Ed mk1 '66 wrote:My diff has already been modified, but I'm not sure yet what the ratio is at the moment. The previous owner couldn't tell me exactly, he only knew that it was modified, but not to what ratio. how can I check this?
have a look on it to see if the tag is still there (on the bolts that hold the diff cover on) it should have some numbers stamped on if it's a 4.63:1 thats the best one the other i think is 5.1:1 :)
if the tag isnt there you could jack up the rear axle turn the prop round and count the rotations of the wheels :idea:
but if it was an origanal 5.8:1 you would tell it's like driving round in 3rd gear :lol:
Ed mk1 '66 wrote:What about a 2.6l HC engine from a Taunus 26M, I can get hold of one.
not sure :? it's not a very common engine over here :) - mabe someone esle could advise on that :D
Postby ake » Sat Aug 01, 2009 8:44 am
Is that a genuine Ford Water bottle Luke, or a cheapo pattern part :?: :lol: :lol: :lol: :lol: :lol:
Postby Ed mk1 '66 » Mon Aug 03, 2009 2:46 pm
For those who are interested, here are two pictures of my beauty, it's the firevan, on these pictures next to the ambulance that belongs to a friend of mine, very soon we're planning on going on a little tour together.
Ed mk1 '66
Postby Luke » Mon Aug 03, 2009 4:28 pm
they are both very nice mate 8) 8) are you keeping it looking like a fire engine or do you plan on taking of the stickers and the light :?:
ake wrote:Is that a genuine Ford Water bottle Luke, or a cheapo pattern part :?: :lol: :lol: :lol: :lol: :lol:
genuine vimto :lol: :lol:
Postby Ed mk1 '66 » Mon Aug 03, 2009 4:36 pm
I will keep it like a firevan, but I will pimp it up a little.
I am pretty much inspired by this clip on youtube:
http://www.youtube.com/watch?v=gGDxtTlqYu8
I like the striping, white wheelsides and racenumber on the side, but I will keep the blue light and the painting on the doors from the original german fire-squad, which it belonged to until 1997, the racenumer will have to be 66 (year of build)
And I will paint the front grill white, as well as the little wings on the sides of the grill, to emphasize these beautiful shapes
Ed mk1 '66
Return to Mk 1 & 2
