V4 Essex Engine - Leaky Water hose question?
Postby welshrussell » Sun Aug 02, 2009 6:49 pm
Well, today after taking the van for a test run before going on holiday next Thursday - I sprung a leak :o
After about 80 miles of A roads and a good cruise I was about 200 metres from home when the temp started going up pretty quickly :shock: , so I pulled in stuck my head under the bonnet, to find - water pishing all over my dizzy cap :?
Looks like a tiny pin head size hole appeared in my hose that comes from the water pump to the thermostat housing. It's on the bottom left of this photo:
So, I let her cool down, whipped some duct tape around it, refilled the rad and then finally got the van parked up :roll:
So my question is, do I need any special pipe or is there a certain type/size I should be asking for :?:
I've taken off the leaky one and will get to a motor factors on Wednesday to ask them if they have something like this in stock :?
Check out the Progress Reports Section if you want to see some photos of my MK1 Campervan after it's respray and engine rebuild 8)
Do good things - and good things will happen to you!
welshrussell
Re: V4 Essex Engine - Leaky Water hose question?
Postby Ed mk1 '66 » Mon Aug 03, 2009 1:07 am
When I need hoses like that I go to a hydraulics retailer in my town here in holland. He has rubber hoses in every size and most of the times that's much cheaper than bying (original) parts from a dealer. A few months ago I had a leak in a hose that's between the oil reservoir and the oil pump of my power steering system on my '95 transit. The Ford dealer could order an original hose for €42,-, but at the hydaulics retailer I bought a piece of rubber hose that fitted perfectly for only €3,-
I guess that coul work as well for your cooling system.
Ed mk1 '66
Postby welshrussell » Mon Aug 03, 2009 8:52 am
Ed mk1 '66 wrote:When I need hoses like that I go to a hydraulics retailer in my town here in holland. He has rubber hoses in every size and most of the times that's much cheaper than bying (original) parts from a dealer. A few months ago I had a leak in a hose that's between the oil reservoir and the oil pump of my power steering system on my '95 transit. The Ford dealer could order an original hose for €42,-, but at the hydaulics retailer I bought a piece of rubber hose that fitted perfectly for only €3,-
Cheers Ed - I reckon you are right about this :?
I think an original part would be way too expensive (if you could find one) :o
welshrussell
Postby baconsdozen » Mon Aug 03, 2009 10:21 am
Its standard heater hose,available in different bores,a decent facors should have reels of them.
baconsdozen
Postby welshrussell » Mon Aug 03, 2009 10:39 am
baconsdozen wrote:Its standard heater hose,available in different bores,a decent facors should have reels of them.
Cheers Kevin, I'll be going to the Factors tomorrow :D
welshrussell
Postby welshrussell » Wed Aug 05, 2009 9:42 pm
Right - all sorted from the Factors with water hose, everything bolted back on and refilled - she seems to be running ok now :D
Even managed to pick up a new engine temp sender :D
welshrussell
Postby madmark » Thu Aug 06, 2009 4:44 am
russ get out there and get that v4 working :lol: :lol: :lol: :lol: :lol: hollidays here you go!!!!!!! :lol: :lol: :lol: :lol: :wink:
Return to Mk 1 & 2
