Where is the chassis number stamped on the mk1?
Postby Damien89 » Sun Aug 16, 2009 3:54 pm
Hi, apart from the two plates in the step, were is the chassis number stamped on the mk1?
Also till what year was the ignition key in the dashboard near the speedo? When did they start putting the ignition in the sterring column?
Thanks.
Damien89
Re: Where is the chassis number stamped on the mk1?
Postby Damien89 » Mon Aug 17, 2009 11:24 am
Nobody? :shock: :?
Damien89
Postby transitgeoff » Mon Aug 17, 2009 11:36 am
front spring hanger if its still there
transitgeoff
Postby madmark » Mon Aug 17, 2009 2:16 pm
ignition on the steering colmn was after 70 as a option :wink: as geoff says front spring hanger but on many its unlikely to be there because of rust ishues :wink:
Postby Damien89 » Tue Aug 18, 2009 8:32 am
Thanks! :D
Damien89
Return to Mk 1 & 2
