Can I put a Mk3 Engine and box into a Mk2???
Postby chrisjhallm3 » Mon Aug 17, 2009 2:25 am
Hi. I have a 1985 transit recovery truck with blown engine, I also have 1994 2.5 diesel banana engine van. Can I transplant. what do I need to change, what are the pitfalls. Many Thanks
chrisjhallm3
Re: Can I put a Mk3 Engine and box into a Mk2???
Postby Luke » Mon Aug 17, 2009 9:21 am
try a search - there tons of info on fitting a Di into a mk2 on here :D
it'll go but easy but how easy depends on what engine you have now :D
Postby redeemer » Mon Aug 17, 2009 11:11 pm
what can I think of :
gearlever must be shifted a few inches sideways
g/box cross member needed for the Mt75 g box
engine mountings should be of the slanting type or if on the new engine they are different, they can be replaced by unbolting them from engine
also different prop shaft as first piece should be of different lenght, and differnet flange pattern.
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Return to Mk 1 & 2
