Brakes - Mechanical Novice!
Postby MK1Chris » Mon Aug 17, 2009 1:17 pm
Armed wtih a haynes manual and some of my old man's tools, I set about replacing the brakes on my MK1 on Sunday.
New parts to fit:
2x new front discs
new front pads
new rear shoes
new rear cylinders
Eventually managed to dismantle the passenger side front assembly and after a good 30 mins with disc and hub in a vice and use of a big hammer and a whole can of WD40, managed to seperate the two and refitted the front disc with no problems.
Front pads were simple to extract, but one piston on the caliper won't go back into the caliper body - must be siezed... damn :evil:
Rear brake shoes... blimey, what a fiddly job to remove them! Is there a simple way of removing the hub from so I can see the whole brake assembly? Seem to need a special tool to remove the rear hub cap... something with two circular pegs to fit into the holes in the hub cover?
Found out I had the wrong brake shoes so couldn't re-fit them anyway.
Would be completely lost without Haynes lending a hand :lol: :wink:
Questions for somebody who knows what they are doing:
1. How do you stop the brake fluid coming out when you disconnect the calipers and cylinders?
2. Any tips for replacing the rear brake shoes. Appear to need fingers the size of a small child, but with strength of 3 men to connect the springs again!
3. Anybody used Biggred to re-furb calipers before? http://www.biggred.co.uk/caliperpricing.html
MK1 CI Motorhome.
Original 2Litre V4 and 4 Speed Manual with 29k on the clock (now up to 31k!)
Rusty problems soon to be sorted. See my progress in the projects section... http://fordtransit.org/forum/viewtopic.php?f=27&t=28696
MK1Chris
Re: Brakes - Mechanical Novice!
Postby imustloverust » Mon Aug 17, 2009 2:23 pm
1. I just left a jar under the hose to collect lost fluids when i disconnect brake lines. They'll have to be bled anyway.
2. I assuming their not mush different from mk2. If you connect up the springs at the top first and get the shoes in place on the brake cylinder but dont put the bottom of the shoes in their place just yet. Connect the bottom spring, should be easier as the holes can get closer together. Then place the bottom of one shoe inside its mount and using a large flat blade screwdrive lever the other side into place. The top of the shoes will probably have moved again so check they're in place. Hope this is clear enough.
3. Front brake caliper pistons are often hard to push back in especially if the brakes are well worn. Sometimes you can bolt them back on without the pads and using a lever push the cylinder back in.
Best of luck!
imustloverust
Postby MK1Chris » Mon Aug 17, 2009 3:35 pm
Thanks for the tips mate - just finding it tricky on the rears to get the little springs in the right places - especially with the self-adjusting mechanism in there as well!
Tried to push the pistons back in using a set of mole-grips and it still wouldn't shift. Must be siezed!
MK1 CI Motorhome.
MK1Chris
Postby Luke » Mon Aug 17, 2009 3:43 pm
mole grips arnt really ideal for pushing pistons back in - better of with a G-clamp if you've got one :D
Postby italjet » Sat Sep 05, 2009 1:30 pm
hello.... just joined the club, also just bought mk 1 camper, 1977. my brakes are...... scary. is that why you are changing all yours?.......jim
italjet
Postby baconsdozen » Sat Sep 05, 2009 4:20 pm
Use a piece of nylon twine to pull the springs on (cut it off afterwards) and a piece of clear polythene under the filler cap will reduce fluid loss to a trickle if the cylinder is well filled first.
baconsdozen
Return to Mk 1 & 2
