Looking for a retaingclamp early mk2 york, part or partnumb
Postby frankwilliams » Tue Aug 18, 2009 9:11 pm
Hi,
I'm looking for a retaing clamp which should retain the outer cable of the "stall engine" cable. (or how do you call this in correct Englisch?)
My transit is a 1978 mk2 whith a york diesel.
I have to shut the engine down whith this pull cable instead of the ignition key.
Now the outercable isn't reatained properly, so i have to pull the innercable further every time......
On the pictures you can see that the previous owner tried to fix this with tywraps.
I would like to have the original part, or the partnumber so i can try ordering one from the dealer.
Who can help me??? By providing a part, or partnumber.
Thanx in advance,
With kind regards,
frankWilliams
frankwilliams
Re: Looking for a retaingclamp early mk2 york, part or partnumb
Postby mikecurd2005 » Sun Aug 23, 2009 1:27 pm
This is a spring clip that was used on many other fords. I think you would still get one from fords, I am about to scrap a mk2 with the york diesel so I will try and grab it off for you. If not I will have one in the workshop that is one of the bits that commomly gets lost when it pings so I will have a few somewhere. Be in touch soon.
Mike
mikecurd2005
Return to Mk 1 & 2
