Pinto to Di conversion
Postby Decky75 » Thu Aug 27, 2009 3:06 pm
Hi, can someone point me in the right direction for doing a petrol to diesel conversion on my mk2 swb minibus.
Im using the engine and gearbox out of the mk4 that im breaking so have the full donor van.
My main concerns are what to do with the petrol tank, prop, electrics, and axle?
Any advice would be great as Im starting the conversion next week.
Decky
Decky75
Re: Pinto to Di conversion
Postby oldskooler » Sun Aug 30, 2009 9:03 pm
well it looks like ill be doing this conversion soon as well. all info welcome!!
oldskooler
Postby Decky75 » Tue Sep 01, 2009 11:53 am
?? :roll:
Decky75
Postby Luke » Tue Sep 01, 2009 2:01 pm
Decky75 wrote:?? :roll:
problem is it's been asked many times before - search and you'll find what you need to know :D
but............
prop - have a front end of a mk3/4/5 fitted onto your prop
axle - just leave it
electrics - dead easy unless you get a epic one its just 1 wire
tank - take off the in tank filter it its there and fit a return line
the other thing i'd reccoment is you get the floor area round the stuck from a mk3/4/5 and weld it into your mk2 it'll fit easy makes it a much tidier job :D
Postby Luke » Tue Sep 01, 2009 10:06 pm
Luke wrote:the other thing i'd reccoment is you get the floor area round the stuck from a mk3/4/5 and weld it into your mk2 it'll fit easy makes it a much tidier job :D
this bit
Postby manandvan » Sat Sep 05, 2009 9:27 pm
you may need engine mounts if your donor van has the alloy ones, if so i have loads of them. :D
manandvan
Return to Mk 1 & 2
