Has anybody ever had to remove the rubber stops directly above the rear axle in Mark 1 Transits with dual rear wheels?
It's raining and cold outside so I cannot have a look to measure anything and I was thinking of replacing the rubber stops with slightly taller ones (1-2") to prevent the wheels touching the floor which it will do if overloaded and in rough roads (no wheel arches in this one).
What are the alternatives to these rubber stops?
Air bags?
Rubber stops with progressive compaction so they actually help the springs at some stage before suddenly going bump?
There has to be something better than what Ford decided to put in this thing 33 years ago.
This job will have to be done in conjunction with newer and slightly higher springs, of course, and one or two inches higher is what I had in mind.
