pip as a matter of intrest are you useing a mk2 overdrive box ,what bellhouseing are you going to use? if you fit the v4 one i think its shorter
this might make the mainshaft to long ,if you are useing a complet box from a 3ltr you will be ok! maybe somebody else could shed some light on the subject! could you not fit a mk2 prop from a overdrive swb? and somehow fit the centre bearing carier????? if not you will need to have your prop made with the correct end on ,this will be costly! the overdrive will give you is 1200 revs ,if you are dooing 50 it will go to 62 ish!
