Lower windscreen repair panel?
Postby Luke » Fri Jun 03, 2005 6:45 pm
Has anyone ever seen a repair panel to sort this:-
The wing is no problem i already have a new top half :D , its the bit under the windscreen im after, i haven't prodded it but im 99% sure it will be worse than it looks!! :(
Ive never seen a repair panel available - have you :?:
Postby transitgeoff » Fri Jun 03, 2005 7:05 pm
Hi Luke yes i have seen and had a repair panel for the scuttle on your mk1 its called a mk2 :lol: my mk1 was like that and it had gone through to the dash,i had a mk2 for breaking so removed the wings and found that the scuttle panel is the same at the ends and slightly different in the middlebut well useable :lol:
transitgeoff
Postby Luke » Fri Jun 03, 2005 8:46 pm
Yeah i knew that :D trouble is finding a mk2 good enough, if it is its probly too good to break :D
You can get then for mk1 escorts so why not mk1 transits????? :?
Postby FredTransit » Sat Jun 04, 2005 10:06 am
It's a 50-50 chance that a breaker will be good in that area, ours are that ratio, so it's the luck of the draw how the scuttle ends up. Some of ours have fantastic chassis, but have had to have the screen out, ot the reverse. It does help to have a few to compare to! Ask midnightcalssix, he's breaking a Mk2 and is really nera to you.
FredTransit
Mk2 Trannyist
Return to Mk 1 & 2
