mk2 transit half shaft question
Postby tuscan440 » Fri Jun 17, 2005 8:33 pm
just managed to get the N/R half shaft back in to the diff after my weekend mishap (see other post on this section) where it was pulled out sideways. have replacement bearings and hub and all seems to work well but the half shaft is slightly bent. it fits fine wthin it housing but is this gona be a problem??? cant actually feel any vibration when driving but worried it might shake the new bearing to pieces. what do you rekon??
tuscan440
Postby Luke » Fri Jun 17, 2005 10:09 pm
Mate ive never been in that position but i wouldnt use a bent halfshaft - i wouldn't imagine the bearing lasting too long atall :(
Postby MrMPuk » Sat Jun 18, 2005 12:21 am
A bent half shaft is not a good thing and a vechicle should not be run with one, you might not be able to feel any vibration but believe me it is there.
Postby FredTransit » Sat Jun 18, 2005 12:27 pm
Go to the scappie and get another half shaft. it won't be too much money, and you'll have the piece of mind.
FredTransit
Mk2 Trannyist
Postby Gunslinger » Fri Jul 01, 2005 10:23 am
yup thats knackered, and make sure you get the right length one, a mk3 one will be a little shorter, and seem like it is fitting, but will morethan likely strip the splines in a short period of time
Gunslinger
Return to Mk 1 & 2
