by Petrolhead41 » Mon Oct 16, 2006 3:22 pm
On the Jaguar there was the option of fitting a back fire valve which would have protected the wire for the fuel sensor, but as the car was always on LPG l just disconnected the plug to the sensor and it ran on a pre determined setting.
There should be some kind of valve which will do that, the backfire happens on over run when the engine doesn't need the gas and it goes into the inlet pipe. Which then ignites inside the inlet pipe causing the problem, it's nothing to do with a normal type of back fire.
Main thing is to check the fittings, l am sure that insurance compaies specify a certificate of some sort for insurance purposes. If you have one then take it back to where this was issued, if not then you will need to find a garage which fits ( and understands Lpg ) and get a certificate from them.
Without a certificate if anything happens l doubt if you would get paid out from your insurance company.
don't take life too seriously, you're not going to get out of it alive.
